Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I can't receive faxes
Everything on the machine works and I can send faxes but for some reason it won't receive any faxes. It just keeps ringing and ringing.
  • adminguru Mar 19, 2009
    Nothing has changed other than loading new ink cartridges .. I can send faxes ok but not receive them I get a comms error in my brother machines
If you have Distinctive Ring(one line with two separate ring tones.
1. Press Menu
2. Press up or down key to choose FAX and press OK
3. Press up or down key to choose Miscellaneous and press OK
4. Press up or down key to choose Distinctive and press OK
5. Press up or down key to choose SET and press OK
6. Press up or down key to choose the ring patters that your phone company has given to you as
the second line. You will notice that each ring patters is different, However One should match the
ring pattern that the Phone company has assigned to you..
** Once you have found your ring pattern, Press OK.
7. Press Stop/Exit.
Distinctive Ring is now set to on.
Posted on Mar 23, 2009
    Problem Solver:
  • 14 Answers
Your fax is likely set to manually receive faxes.
To set the receive mode to Auto follow the instructions below.
a Press Menu 0, 1.
b Press a or b to choose Fax Only
c Press OK.
d Press Stop/Exit.
Posted on Feb 04, 2009
    Problem Solver:
  • 6 Answers
If this is @ your home it might be sharing a house phone, or check with phone company to see if there any speical features on your line, call and check the line,your fax line need to be a stand alone
AUTO ANSWER on fax receive does not answer fax.
You need to talk to HP tech support... to do a proper reset you need to access menus that are meant for tech support and developers only. If you "brick" your OJ using those menus on your own (including instructions from anyone here), it's considered customer damage and voids the warranty. If you post your request at the link below, you should get a PM from an official HP tech support person telling you how to do the reset.
Officejet 6700 premium won pick up faxes
Mar 07, 2015 | HP Officejet 6700 Premium E-All-In-One...
FO-3150-won't auto answer, have to pick up receiver to get faxes
renield, that worked perfect!!! Thanks a million!
Feb 06, 2013 | Sharp Fo-3150
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
Can send but not receive faxes. dell 1815 dn. I can do everything else, just not receive faxes, went through help lists and have follow everything to no avail...i need it to work:(
Did you check the "answer call after x rings" option?
It sometimes defaults to 7 rings, at which time the sending fax machine has given up already.
You find the settings here: "Fax -> Fax Defaults -> Rings to answer"
If this solved your problem - great!...If not, just come back and leave a comment - I'm happy to help.
May 22, 2010 | Dell 1815dn All-In-One Laser Printer
I can send a fax, but can not retrieve. Line continues to ring,
Press the START button while it is ringing. Scroll through the menus and set your machine to AUTO RECEIVE.
Jan 26, 2010 | HP Office Equipment & Supplies
I am having problems receiving a fax.
Check the number of rings your fax machine is set to. Chances are, the answering machine is set up for 4 rings and the fax machine is set up for 6. If this is the case, change the number of rings on your fax machine to 2 or 3 rings to ensure an incoming fax will go directily to the fax machine. If the fax doesn't recognize the call as a fax, it will go through to the answering machine.
Jul 17, 2009 | HP 1040 Plain Paper Inkjet Fax
Canon 1023if not receiving faxes automatically
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
It has worked for me in serveral other installs
Hope this helps
TankMurdock
Apr 09, 2009 | Canon imageRUNNER 1023iF Black and White...
LEXMARK X5495 New printer, can't send receive faxes
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines
Jan 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cant receive faxes
Set your fax machine for AUTO RECEIVE. Unplug power cord and plug back in.
Sep 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
151 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
