Question about Hitachi 70VS810 70" Rear Projection HDTV
My Hitachi 70" LCD will not turn on
Last week my Hitachi 70" LCD lamp burned out. so I ordered a new lamp from Hitachi online store. when it came in the mail I installed it by following the instructions that came with the lamp. when I plug it in the power light comes on it blinks follow by the 2 other light (temp) & (lamp) and then the (lamp) light stays on but the tv will not turn on at all please help somebody
I did everything that the instruction told me to do, I even closed the door and tighten the screw
  • mhenderso871 Feb 24, 2009
    I am having the same problem. My (Hitachi 70VS810) television would not turn on one day & the red light (lamp light) came on. So I called out a Hitachi "Certified" Technician who checked it out & said that the lamp needed to be replaced. He said I could order it from Hitachi for around $200 or he can order & install for around $750...I ordered the lamp, installed exactly as the instructions say - made sure everything was tightened and put back how it was prior to ever opening the cover. Plugged the TV in, pushed the power button and all that happens is the 3 lights light up for about 2 seconds then the red lamp light comes on and starts blinking.
  • mhenderso871 May 11, 2010
    I tried that and there is no tab that sticks out. Once the cover is removed, you can see a tab that goes into this particular spot. I have tried readjusting over & over & can't get it to work... When I plug it back in I can hear a click sound as if it has been powered on, then another click (as if powered off) that is when the lamp light starts blinking.
    President:
  • Hitachi Master
  • 1,779 Answers
Take the door back off and look for a safety tab somewhere on the door that will activate a small safety switch, the tab will stick out. Maybe you broke the tab off or just didnt get the door on correctly. Try that and let me know.
Posted on Feb 04, 2009
  • michelleb242 Nov 15, 2010
    I tried all of the above and no luck but THEN we realized we had it plugged in to the surge protector not the battery backup. Once we plugged it in to the battery backup it powered up like a champ! Good luck!
My Hitachi 50V500A has a large area where the color is turning out to red. Is this a lamp or a complete light engine replacement job?
not the lamp. hitachi knowingly had a defect with the fan not allowing enough air to cool the lamp which has burned the red color lense resulting in the red on your screen. enjoy your new brick thanks to hitachi!
Jan 09, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
Jvc 70' lcd tv. power indicator light flashes fast upon power up. no picture
The lamp is burned out, this is an easy fix. Contrary to what the "repairmen" on this site say, you can do it at home with ease. Just type your model into a search engine and order your lamp, they come with great instuctions on how to install.
Dec 21, 2009 | JVC HD-70FH96 70" Rear Projection HDTV
We bought our Hitachi 50" tv in 2004. Recently it had a blue cloud and finally the lamp went out. We replaced it after ordering the part from Hitachi. This has been only a few weeks ago. The blue cloud is...
id guess your set is like a 50v500 or 50v720 its a lcd rear projection
the blue cloud come from a warped lcd plate in the optic engine and would require replacment to correct this problem
if you have a extended warranty you would want to contact them
if not you might contact hitachi consumer affairs and ask them if there would be any assistance with this repair
Jan 01, 2009 | Televison & Video
Lamp and Temp light flashing
Had the same problem last week.... the lamp has gone out. It can be done by anyone with basic electronic skills....the lamp is about $100 online, more if you by it from a local repairman because he will want to do it, and of course, the quote I got was almost $300.00. I ordered lamp online for about $129 to get it to me and had brother put it in. Didn't look too difficult, so I probably could have done it but I didn't want to ruin my tv. I just posted the manual for this TV on owneriq.com that tells how to do it.
Dec 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi lcd 50" model 50V500A - turn off & on
Best advice I have is to price shop for lamp online using lamp or model number. Now it could be lamp or ballast or dmd causing this. But most common is lamp and you will need one sometime anyway. Very easy to change. Also probably a parts dist. in your area stocks it. Good luck.
May 27, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
I replaced the burnt out lamp,not working !!!
This may sound crazy. If you still have the old lamp. Put new lamp in old housing, and try that.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TV Problem
It is a failure in the light engine itself. You will need to have it replaced. Here is a link to that rather costly part. http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50V500/Hitachi+Ltd/Hitachi/UX22201D/New.aspx
Apr 05, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Open Questions:
See all Hitachi 70VS810 70" Rear Projection HDTV Questions
Hitachi 70VS810 70" Rear Projection HDTV Logo
455 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
