Question about Everex StepNote LM7WZ Notebook
MY fan only spins at the startup screen
When i power on my laptop, the fan spins, but then once i reach the user select screen, it stops completely, making me unable to use any USB hard drives, or sync ipods because it'll heat up, and then my computer will freeze.
  • pcdoc63 May 11, 2010
    You might check in the BIOS of the laptop to see if there is a "cool and quiet" function or something.  Often there is also a place where you can set the temperature threshold, or how it acts upon boot.  Look there and let me know if this was helpful.
    les
  • 679 Answers
If you are running with no fan, you will burn out the processor, stop and send that puppy in for service, please do no attempt to fix it at this point, you will be lucky if it has not burned out . I do this all day, and I take big risks but no cpu cooling is doa, leave it and send it back to the manufacturer, if it's off service or warantee, take it and get an estimate, then if you are going to toss it if it's not on warantee and it's too expensive to fix, then you can mess with fixing it
Posted on Feb 04, 2009
How do I unlock my password or reset my pc while I forget the password?
Hi, Try logging into safe mode by pressing f8 during your pc startup, once the menu becomes available select safe mode and press enter, next let the pc load until you get the user selection screen. select administrator, once you enter the account go to control panel and find administrative tools, select local users and groups and enter it, next find your user name, right click on it and click reset password. This should work for you.
Jan 16, 2015 | Microsoft Computers & Internet
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
I have a presario cq61 and have forgot my password can u help
Try starting the computer in safe mode. Turn on the computer and once the COMPAQ screen clears press F8 a few times - don't hold down the key however. Winodws stops loading at teh Startup Options screen (black, text only). From that menu use the cursor keys and ENTER to select "Safe Mode". Once Windows loads (it may look humungous!), login as the Administrator (which should now be visible). Use this account to reset your forgotten user password. Restart once complete - the computer will automatically start normally.
Apr 14, 2011 | HP Compaq Presario CQ61420us Notebook
When I boot up my t61 it starts to spin up then halts. The AC power and battery power indicators are green as is the power indicator. I thought it might be overheating so blew out the fan with...
Most likely the hard disk has just died - try to access the BIOS and see if it's still recognized. For that ress the blue ThinkVantage button when the message "To interrupt normal startup, press the blue ThinkVantage button " is displayed and then select Start setup utility .
If nothing appears on the screen then the defect is in the motherboard - you will need to take it to a service center to determine if the board must be replaced.
Apr 02, 2011 | Lenovo ThinkPad T61 Notebook
My laptop will startup but as soon as it reaches the loading for windows it shuts itself off.
The problem you have can be fan problem.
If the laptop is still under warranty you should take it to assistance.
Mar 01, 2011 | Computers & Internet
A disk read error occurred Press Ctrl+Alt+Del to restart
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that screen but you end up reaching the Blue/Black screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER
if this fails then try repairing it from recovery console.
  • Insert the OS CD and boot from CD.
  • During Startup, select Recovery Console from the startup options menu.
  • When you are prompted, type the Administrator password.
  • Type the Command chkdsk /r
Dec 07, 2010 | Acer Aspire 6920 Notebook PC
When i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the...
that means that your ram is good..real nice of you to have check that...now see if you can get a spare cooling fan..cause i guess that your fan has reached its limit or heat sink overheated..
Jul 30, 2010 | Acer Computers & Internet
MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Feb 15, 2010 | Apple MacBook White- 2.1GHz Intel Core 2...
Hard disk crashed on macbook
You can tell if your hard drive for your Macbook Pro has really crashed, if you attempt to run these 3 diagnose and repair procedures and there is no response from the hard drive:
1st Procedure:
font.f1 {font: 12.0px Helvetica} font.f2 {font: 14.0px Myriad Pro} - USING FSCK COMMAND TO VERIFY AND REPAIR DISK-
Start up your computer in Single-User Mode to reach the command line by doing this:
•Make sure your Mac is shutdown.
• Reboot your Mac
• When Mac starts up, press the Apple Command key+ S Key
- A black screen, with white text appears
• At the command-line prompt, type /sbin/fsck -fy
• Press Return.
--fsck will run through a series of tests and will return information about your disk's use and fragmentation. When completed, it will display this message if no issue is found:
The volume (name_of_your_Mac_volume) appears to be OK
If fsck found issues and has altered, repaired, or fixed anything, it will display this message: --FILE SYSTEM WAS MODIFIED--
Important: If this message appears, repeat the fsck command you typed at the beginning, until fsck tells you that your volume appears to be OK (first-pass repairs may uncover additional issues, so this is a normal thing to do).
• When fsck reports that your volume is OK, type reboot at the prompt and then press Return.
• This last command after completing the fsck process, is going to attempt to boot your Mac to the main desktop.
If unable to reach your Desktop with the fsck procedure, go to the next step.
Procedure # 2
font.f1 {font: 13.0px Myriad Pro}
-RUN DISK UTILITY WITH STARTUP DISK-
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the startup disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Mac
* If you have still not gotten a successful boot to your main desktop, try this final step.
Procedure # 3
My recommendation for this issue, is that you use the Archive and Install procedure to resolve this issue.
What this process consists of (using your Mac OS X install disc),is removing the damaged or corrupted Mac OS X directory and replacing it with a brand new directory.
This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files.
-ARCHIVE AND INSTALL-
• Start up from your Mac OS X Install Disc 1 or Install DVD. Please remember to use the install disc that matches the current operating system your system haves.
Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key.
• Hold the C key until you see a White screen, with a Gray Apple icon and eventually a Spinning gear.
-Your mac will now boot from the disc and load into the Installer environment.
• Select your language. The Welcome to the Mac OS X Installer window appears.
• Click Continue. The Important Information window appears.
• Follow the prompts until you get to the licensing agreement screen
• An agreement sheet appears. If you agree with
the license agreement, click Agree. Then Select a
Destination window appears.
• Click the volume that you wish to install to (your primary hard drive).
• Click Options. The installation options sheet appears.
• Select Archive and Install.
• Select the volume which already has Mac OS X installed.
• You should also select Preserve Users and Network Settings, to preserve network and Home directory settings.
• Click OK.
• Click Continue to begin the installation.
• Once the Archive and Install is completed, when you reach your desktop be sure to run all Software updates to bring your new Mac OS X directory back
up to current.
Also, if you look inside your Macintosh HD icon on your Desktop, look for a folder entitled "Previous System Folder" which will have all of your previous Home folder files prior to the Archive and Install.
Here is the link (below) from Apple for more information about how to locate the Previous System Folder
How to locate Previous System Folder (after Archive and Install)
If there is still no responsiveness of the hard drive after this last procedure, your best option would be to take your Macbook Pro in for repair or replacement of the hard drive, to your local Apple retail store Genius bar or local Apple authorized service center.
Best Regards,
-Mactechtrainer
Jan 29, 2010 | Apple MacBook Pro PC Notebook
Compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Mar 11, 2009 | HP Compaq Presario C500t Notebook
Open Questions:
Everex StepNote LM7WZ Notebook Logo
52 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
