Question about JVC Everio GZ-MG360 HDD Camcorder
Access lamp stays blinking
Is the access lamp suppose to stay blinking after I closed the screen?
3 Suggested Answers
SOURCE: JVC HD-527575 problem
We just had the same problem. The Projector lamp is burned out. You can get the lamp at Electrified.com. Their phone # is 800-678-8585
Posted on Oct 22, 2008
SOURCE: jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Posted on Dec 07, 2008
On my 2001 porsche boxster is the daytime running lights supposed to stay on or blink
They are supposed to stay on. Why would they blink? Are you referring to the turn signals? They're the only ones that should blink.
Dec 10, 2012 | 2001 Porsche Boxster
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
Are the lights suppose to be flashing
The WAN lamp should blink whenever you are accessing the Internet.
The WIRELESS lamp should blink at a fixed rate.
Each of the LAN lamps should blink whenever that computer is accessing the Internet.
Sep 17, 2010 | NetGear WGR614 Wireless Router
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
Replaced lamp, still does not turn on.
LAMP #BP96-00826A
IF THE TV STAYS ON FOR 30 SECONDS IT MAY BE AN INDICATOR OF A POSSIBLE POSITIONING ISSUE WITH THE LAMP DOOR SWITCH (LITTLE BLUE SWITCH AT LOWER LEFT OF CABINET WHEN LAMP DOOR IS REMOVED.) THIS SWITCH IS SUPPOSE TO BE IN THE DOWN POSITION ONCE THE LAMP DOOR IS SECURED AND HAS CAUSED CONFUSION BEFORE.
HOPE THIS HELPS
Jul 06, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
Ready lamp on 283
When the flash goes into battery saver mode, which it does automatically, the light will blink.
If you are using the external power source, the light should remain steady.
Jeff
Oct 30, 2008 | Vivitar 283 Flash
Front turn indicator stays on
bad lamp or it is loose lamp replace lamp check connections
Sep 09, 2008 | 1999 Chevrolet Blazer
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
JVC Everio GZ-MG360 HDD Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
