Question about Hobart N50 Stand Mixer
May need lubrication out of use 15 years
Kitchen-Aid Model 3B serial# 3B197685 What type of lube and how to apply. Also we need a hook for bread making.
  • 135 Answers
Hi Snowbird. Your mixer was manufactured in late 1940's or early 50's. It was sold with one all-purpose combination whisk/beater. There is no dough hook available from Kitchenaid. There are two greases you can use in your mixer. Shell Darina-2, or Chevron FM ALC EP-2, the Chevron product is rated as "food grade", meaning that it is safe to ingest if it drips into the food you are mixing.
Remove screws and cover to expose the transmission. Remove all traces of old grease and replace it with one of the above "approved" greases. If you find this solution helpful, please rate it. ricardok45
Posted on Feb 13, 2009
Is this a Kitchen Aid? Is it possible to buy this circuit board from somewhere?
This is a kitchen aid. BUT!!!! it is an international model that was sold in countries with 220 volts. Look underneath the mixer for a white tag it should have a model number and a serial number, if you can get us those numbers then we can help with the parts. Hope this helps.
Nov 05, 2014 | Food Mixers
Motor head on Kitchen Aid KSM150PSWW is loose when in operation.
Are you engaging the head lock during operation? if not that is why it is loose. If you are it is not uncommon for the head to move around a little under heavy loads, when I make bread the head is always trying to come up so I have to use the head lock switch whenever I use the mixer on bread. It is the only time I lock it down.
Sep 05, 2013 | KitchenAid Kitchen Aid KSM150PSWW -...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Hello. I have a Kitchen Aid mixer made by Hobart between 1975 and 1978. It is a stand mixer with a 5-quart bowl that lifts and locks into place. While it was kneading a bread dough, the motor...
Hello Suzann,
I understand that you are having a problem with your Kitchen Aid 5 Quart mixer. It sounds like you have stripped the gears or the worm gear out. Although, it may not be an expensive parts repair it is not an easy task to complete if you are not mechanical enclined. There are many different little gears in these units.
My suggestion would be to take it a local appliance repair shop that works on mixers. If you can tell me the city that you live in I would be more than happy to give you the location of one or two repair shops. As the unit is so old you want to invest in a new unit and keep that one as a reminder of how long Kitchen Aid has been around.
Thank you for choosing FIxYa.com
Justin Burnett
Mar 16, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
I was given a Kitchen Aid 45SS mixer that is over 20 years old but never used. Is there oiling or other maintenance procedure I shoild perform before using? Thanks. Chuck Volkema
I read thru the owners manual for this unit and there is no recommendations for internal service. no reference to lubrication except for keeping the outside free from flour caking up on the moving parts. I have one of these and have seen the inside, they are built like tanks, you should be fine. i would recommend letting it run for a while on low speed to speed the lube around the internal parts, nothing more should be needed. Just make sure it doesnt sound as if the motor is laboring on low speed, this would indicate that internal lube is necessary. I think it will be fine...Worm1855
Jan 18, 2011 | KitchenAid K45SS Classic Stand Mixer
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
Hobart N50 Stand Mixer Logo
302 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
