Question about E-Machines (T2958) PC Desktop
Desktop pc slot
How do I open a desktop emachine pc slot to put in a pc adaptor for my desktop to go wireless?
  • 3 Answers
There are six screws on the back of the tower: 2 on top, 2 on left, 2 on right. Remove these, then pull back & up on the metal case and you're in.
Posted on Feb 04, 2009
    Problem Solver:
  • 13 Answers
Unscrew the screw that holds the little piece of aluminum blocking the slot on the inside of the case.
Hope that I can be of help
Is it possible to make my W3506 Desktop Emachine wireless?
If by wireless you mean you are looking to be able to connect to a wireless router, then yes, it is simple. You can either install a wireless card inside the computer, if you have an empty slot available, or you can get an external wireless card, which plugs into an open USB port, the easiest way to go. Best place I know to find these is at www.newegg.com, or try Amazon.
Aug 01, 2013 | E-Machines eMachines Desktop PC
Where do you plug in the adaptor on the e machine for wifi
Depends on what kind of Wireless Adapter you are using
There's the Wireless Adapter Card
Comes in three styles of connection,
1) PCI Wireless Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
2) And PCI-Express x1 Wireless Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1068811&CatId=2688
PCI-Express x4 style may be out there too.
(I've never bothered to look. I use the USB style)
A Wireless Adapter Card based on the PCI technology, goes in a PCI slot. Generally White in color, but NOT always,
http://en.wikipedia.org/wiki/PCI_local_bus
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
A Wireless Adapter Card based on the PCI Express technology, is used in a PCI-Express x1 slot,
http://en.wikipedia.org/wiki/PCI_Express
http://en.wikipedia.org/wiki/File:PCIExpress.jpg
Top example is a PCI-Express x4 slot.
Moving down, next is a PCI-E x16 slot
Next, PCI-E x1 slot
Next is a PCI-E x16 slot,
and the last one at the bottom is a PCI slot.
Notice they are all Yellow.
Color of connector does NOT matter.
What the expansion slot is, does........
Also there is a USB Wireless Adapter,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3970955&CatId=2704
This type of Wireless Adapter, plugs into any available USB port on the computer.
Front or back of an eMachines desktop computer, in any available USB port.
Any available open USB port, on an eMachines laptop.
(Or any computer manufacturer)
What is the model number of the eMachines Desktop PC?
Examples, T1090, T2460, W4685, D2246, etc.
I should be able to tell you what motherboard is used inside, and may have access to a link, to the Motherboard Manual.
Post back in a Comment.
Regards,
joecoolvette
Apr 14, 2013 | E-Machines eMachines Desktop PC
How to make usb to make emachine wireless
You can buy USB Wireless adaptors at any computer shop.
Jun 23, 2012 | E-Machines eMachines Desktop PC
Can't install wireless network adaptor on emachines 5260. I used to connect to the internet using the wireless adaptor until I re-installed the windows xp operating system due to other problems, and...
Your machine was difficult to track down. As far as I can tell, the 5260 is the Intel motherboard. Below is a link to a page where you can individually download the drivers you require. Best of luck!
Greg
Intel 5260 Windows XP drivers
Nov 02, 2011 | E-Machines eMachines Desktop PC
Expansion slota
eMachines Support > ET1331 desktop computer > Product Views > Rear View,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
Jun 25, 2010 | E-Machines eMachines Refurbished EMA...
How do you open computer to insert wireless card?
There should be 2 screws on the back. The side panel will slide off and then you can insert it into a PCI slot.
If its a laptop get it done professionally
May 20, 2010 | eMachines EL1210-11 PC Desktop
Can't access Internet. Want to install network
You can install the card in any slot you choose, just keep in mind your digital real-estate if you are installing a wireless card be sure lo leave room for the antenna so as to make it easier to plug other peripherals into the computer, just be sure to follow all instructions that come with your card to prevent Damage to the computer or injury to yourself
Mar 08, 2010 | E-Machines eMachines Desktop PC
I AM ON TOTAL BROADBAND HOW DO I CONNECT WIRELESS TO MY COMPUTOR
With a broadband connection you will need a wireless router (you will connect your broadband modem to the router) a wireless adaptor for every computer you want to be wireless. If you have a desktop you can either add a pci wireless card (you will need to open your pc and insert the card in a pci slot) or you can use a usb wireless adaptor.
Oct 28, 2009 | Computers & Internet
I have a TP link wireless adaptor for an acer aspire T180 pc. I can't work out where to fit it on the motherboard
Providing the wireless adaptor is a PCI card this fits the white slot on motherboard.
Should it be USB, then plugs in the USB port.
Feb 22, 2009 | Acer Aspireā„¢ T180 PC Desktop
E-Machines (T2958) PC Desktop Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
