Question about Ricoh Aficio CL3500N Laser Printer
Cant install to Vista pc Ricoh CL3500N
Dnloaded PCL6 driver for Vista,followed Ricohs procedure and nothing,shows in printers but won't print test page from pc
  • 1 more comment
  • Anonymous Feb 24, 2009
    I have a problem showing SC 441 in Ricoh Aficio CL3500N
  • Anonymous May 11, 2010
    Is this set up through a tcp/ip port? Did you create a tcp/ip port during setup of the driver, and use an appropriate ip address?
  • INHS INHS May 11, 2010
    maybe your printer is not compatible in your windows vista..
  • Ricoh Expert
  • 398 Answers
Try downloding the RCPS driver.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
Ricoh CL3500N - not printing all characters on the page
It might be a print driver problem. I think there several different drivers. Go to Ricoh-usa.com and download all the drivers for the operating system you are using and try them. If there is a rpcs driver that might be your best bet.
Apr 24, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh CL3500N not printing black?
Sounds like the Dev unit is about worn out. May also be a transfer issue.
Nov 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
LANGUAGE PROBLEM
The print properties are completely software based and have nothing to do with the printer itself. You've had to have installed the wrong version of the print driver or your operating system is set to the wrong default language. I'm assuming you would know if you were running a foreign copy of Windows so I would uninstall the printer and then download and reinstall the English version from the Ricoh website.
Jun 10, 2008 | Ricoh Aficio CL3500N Laser Printer
Stops Printing Entire Page After Around 50 sheets
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Jun 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh CL3500n form feed problem
Hi TK
I may have a solution for your printer have you tryed to uninstall and re- install your printer drivers in most cases this does the job.
Jan 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
136 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
