Question about Intel Motherboard
Power to everything but CPU fan and case fan - won't boot
Lenovo 738726U (NVIDIA C51g mb & AMD Athlon™ 64 X2 Dual-Core 3800+, socket AM2, 89W)
250G HD
Internal USB Memory Card Reader
DVD/CD Multi Burner
Upgraded to 2G ram
Upgraded to 400w PS
Added XFX 7600GT video
Added wireless network card
Windows XP
Working fine since 12/06
Shut down with Hibernate. Next morning no boot.
CPU fan and case fan not running.
Hard drive is running, DVD light on, Memory card reader light on
Wireless network card light on, power supply fan running
No beeps
Removed video card, replaced with old power supply - no change, no beeps
Removed ram - no beeps
No visible problems on motherboard. No electrical smells.
  • 72 Answers
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Posted on Feb 04, 2009
Want faster processor for acer x1300 it base unit
Here are the spec on your pc if the information you gave me is correct. You can only upgrade the cpu to the socket you have. I think you would be better off adding more RAM and a better video card that isn't onboard. Processor / Chipset
  • Type AMD Athlon X2 7450 / 2.4 GHz
  • Number of Cores Dual-Core
  • 64-bit Computing Yes
  • CPU Qty 1.0
  • Max CPU Qty 1.0
  • Chipset Type NVIDIA GeForce 8200
Aug 18, 2013 | Acer Aspire X1300 Dual Core 2.4ghz, 3gb...
Cpu
AsRock Support > AlivenF6G-DVI Motherboard > Main Support page,
http://www.asrock.com/MB/overview.asp?Model=ALiveNF6G-DVI
In the list on the left hand side, click on CPU Support List
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=ALiveNF6G-DVI
The AMD Athlon 64 X2 5800+ CPU, (Processor), is part number ADA5800IAA5DO.
Operates Up To a maximum frequency rate ('Speed'), of 3.0GigaHertz, has two L2 cache's of 512MegaByte, and uses the Socket AM2 CPU socket.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Brisbane.22_.28energy-efficient_65W.2C_G1_.26_G2.2C_65_nm.29
In the CPU Support :List it is not shown.
This is ONLY because the Athlon 64 X2 5800+, came out way after the CPU Support List was compiled. NOT because it isn't supported.
No, I have to amend that,
http://forums.amd.com/forum/messageview.cfm?catid=14&threadid=108319
It's because AMD's lack of information, apparently, that AsRock didn't list it.
I don't see the voltage range listed anywhere. (To include AMD)
http://www.cpu-world.com/CPUs/K8/AMD-Athlon%20X2%205800+%20-%20ADA5800IAA5DO.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103274
At any rate let's go with deductive reasoning, and see if this CPU is supported.
1) You can compare the Athlon 64 X2 5800+, to the other CPU's in the CPU Support List; that are comparable to it, and above it.
Don't even have to go too far.
Look at the ADA6000IAA6CZ, and the ADX6000IAA6CZ CPU's.
The two Athlon 64 X2 6000+ versions.
(Doesn't state that, just the above part numbers)
However I DO notice that the ADX requires BIOS version P2.00, and the ADA only requires BIOS version P1.60
(Since BIOS)
2) The motherboard chipset is an Nvidia GeForce 6100 and Nvidia nForce 430, Or Nvidia GeForce 6150SE and Nvidia nForce 430
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#For_AMD_processors
Compatible? Yes.
May need the P2.00 BIOS update, if not already installed.
Regards,
joecoolvette
May 16, 2013 | Asrock Computers & Internet
How Do I unlock CPU cores with Bios on MCP61M-M3 motherboard?
The motherboard supports AMD socket AM2 single-core Athlon 64/ Sempron and dual-core Athlon 64 X2/ Athlon 64 FX processors with 2MB / 1MB / 512KB L2 cache, which is based on 64-bit architecture. It features 2000 / 1600 MT/s Hyper Transport Bus, dual-channel un-buffered DDR2 800 memory support and AMD Cool 'n' Quiet! Technology.
The BIOS changes it on it's own when add a dual core.
Here is the PDF file on this board. Chapter 2 explains the Bios.
Jul 03, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
MY SHAUN WHITE GAME WONT WORK ON MY EMACHINES cOMPUTER
does the specification of your PC meet the games minimum requirements? Some eMachines do not have the best graphics cards.
the minimum specs are
OS: Windows XP/ Windows Vista/ Windows 7 Processor: Intel Pentium D Dual Core@2.6 GHz / AMD Athlon 64 X2 3800 Memory Ram: 1 Gb Hard Disk Space: 8 GB Video: 256 MB @ ATI Radeon HD 2600 / NVIDIA GeForce 8600 GT Sound Card: DirectX Compatible DirectX: 9.0 Keyboard / Mouse
Dec 18, 2010 | Ubi Soft Shaun White Skateboarding -...
I want video,lan,audio drivers for amd athlon 62*2 dual core 3800 processor
you need to go to the web site of motherboard to get them if you have a asus go to it jim
Nov 17, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
I have an AMD Athlon FX 2 dual processor and am using Core Temp to monitor the temps of which are posting 44 to 50 while using my computer. Is this normal?
I believe normal temperatures range from 41 to 95. At least from this laptop that is running a dual processor:
http://shopping.msn.com/specs/toshiba-satellite-a215-s5802-15-4-inch-laptop-amd-athlon-64-x-2-dual-core-tk-57-processor-1024-mb/itemid913517877/?itemtext=itemname:toshiba-satellite-a215-s5802-15-4-inch-laptop-amd-athlon-64-x-2-dual-core-tk-57-processor-1024-mb
Also somebody else here had the same type of question:
http://answers.yahoo.com/question/index?qid=20090207210838AA922iE
From my experience as long as its not running over 100 then you'll be fine. If you have any doubts about your computer overheating you can always apply more compound to the heatsink and also buy a bigger one where the fan runs faster to keep things cooler inside of the case and always remember to have the side doors on as well.
Jun 20, 2009 | AMD Athlon 64 X2 4800+, 2.4 GHz...
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
Intel Motherboard Logo
251 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
