Question about GE GDS18LBP Bottom Freezer Refrigerator
Refrigerator not cooling
GE GDS18LBP Refrigerator not cooling, but freezer is working fine.
  • Lady Shea Feb 06, 2009
    I have a bottom freezer unit. I removed the cover under the refrigerator section and there was a lot of ice. I don't understand what you mean by: "IF SO YOU HAVE YOU DEFROST HEATER ,. DEFROST BY-METAL OR // TIMER OR MOTHER BOARD .. " Please explain. Thank you so much.
    Problem Solver:
  • 11 Answers
I THINK YOU HAV A DEFROST PROPLEM .. CHECK AND SEE IF YOU HAVE A LOT OF FROST ON BACK WALL OF FREEZER ./. IF SO YOU HAVE YOU DEFROST HEATER ,. DEFROST BY-METAL OR // TIMER OR MOTHER BOARD ..
Posted on Feb 04, 2009
3 Suggested Answers
  • 52 Answers
SOURCE: GE GDS18LBP Bottom Freezer
Check to see if the evaporator fan is running (the fan inside of the freezer behind the back panel). If it is, pull the interior back panel off of the freezer to see if you have a defrost problem. If there is a large amount of frost/ice, test the heater and defrost thermostat with a multimeter. If they are good, replace the defrost thermostat. Be sure to defrost the ice manually with a hair dryer before you put the freezer back together.
Posted on Mar 27, 2008
heatman101
  • 43501 Answers
SOURCE: GE GDS18LBP bottom Freezer - Refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dl;
Posted on Sep 29, 2010
GE GDS18LBP water inlet value - is it bad ?
look in the freezer and make you the fill tube in not froze up if it is you have a valve that is dripping and then it freezes up the tube. if that is what you have you will need a new valve.
Jun 07, 2017 | GE GDS18LBP Bottom Freezer Refrigerator
Freezer is cold but not fridge
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Mar 23, 2011 | GE GDS18LBP Bottom Freezer Refrigerator
The refrigerator is no longer cold but the freezer is still working?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Jan 11, 2011 | GE GDS18LBP Bottom Freezer Refrigerator
Fridge defrosts but drain eventually freezes up and stops fan
heatman101
Jan 03, 2011 | GE GDS18LBP Bottom Freezer Refrigerator
Top part of fridge is not cooling ?? but the freezer is just fine..
check temp. control, adjust to proper setting. check vents for cold air flow, if theres no air flow, check the freezer,side> check fan, if fan is running, then pull panel out, if there is ice build up behind panel, then you need to check bi-metal, timer and posibly the resistance. good luck.
Mar 06, 2010 | GE GDS18LBP Bottom Freezer Refrigerator
My GE refrigerator GDS18LBPWW with freezer on bottom does not cool in the refrig. section. Yesterday, I pd $239 to have the Evaporator Fan motor replaced. The freezer is fine and back down to 26, but the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The ideal temp for the freezer is around 10 degrees F.
Look at the evaporator coils behind the rear cover inside the freezer and check the ice forming on the coils.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM
Dec 29, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Sides of freezer extra hot
The problem with the fan is causing this. We need to test the fan motor and the power going to the fan motor. Let me know, Sea Breeze
Jul 23, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
heatman101
dl;
Feb 17, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Mar 27, 2008 | GE GDS20KBS Bottom Freezer Refrigerator
GE GDS18LBP Bottom Freezer Refrigerator Logo
282 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
