Question about Air Tools & Compressors
Craftsman 25 gal compressor -- need MOTOR wiring schematic!!
I bought a used 25 gallon Craftsman Compressor, upright, model 919.165230. It was not working when I bought it, the previous owner had accidentally knocked it over and smashed the start / run capacitors on the back of the motor. Tried starting it up when I bought it, it wouldnt quite kick over, and would blow the breaker.
After much research, I found the correct values for the start / run capacitors (start: 30uf, 370VAC. run: 378-454uf, 125VAC)
The wiring is not exactly cut and dry. I tried what looked to be logical, with the start cap, and got it running okay, but I am no certain i have it wired correctly, and dont want to blow $27 worth of brand new capacitors!
Here's what's coming out of the back of the motor (GE motor):
This is besides the power cord to the motor.
coming from the left side of the motor windings:
Orange, Blue, Brown wires. they all go into a ''Klixon CET36SX'', which may have been a breaker or shut-off switch, not sure.
right side:
Red, Red (bound together on one push-on terminal)
Black, Black (separate terminals)
If anyone has this or a similar compressor, and can help me make sense of how the capacitors should be wired in, Please let me know!!
  • 98 Answers
Hey joe if the motor starts up and runs you have wired it correctly if the capacitors werent correct it would not start up and go into run position
Posted on Jul 21, 2009
Why won't my compressor start?
If it's new I would return it. However that model number 16638 is for a Huffy Bicycle.
Sep 06, 2014 | Craftsman 1 hp Air Compressor, 4 gal. -...
We have a Craftsman 15 gallon air compressor, model # 919.166442. It has worked fine for small jobs for the last few years. Went to turn it on and it simply won't turn on. It won't pressurize. Is this...
Hi, my name is John. Welcome to FixYa. Will it come on at all? Check the outlet circuit breaker, if it comes on at all, check where the line comes form the pump to the tank, there got to be a leak, you may have to remove it in order to check under it. Check for a reset button next to the wire coming to the switch. Thanks for choosing FixYa...John
Nov 24, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
I need a schematic Break down of a cummins 2hp 13 gal 115v 15 amp 13 gal tank air compressor Model # TD-5050(1204) Serial # 0702 including price for the electric motor Thank You
I have a TD-5050 13 gallon air compresser that is a 5 Horse running motor. The mmotor will not start on it's own with out me turning the motor by hand to get it started. I have to let all the air out and than spinn the motor to get it started. If I do this it will run for a long time. I think i might have messed it up with using too light of electric cord.
Aug 05, 2010 | Air Tools & Compressors
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
6hp, 25 gallon compressor, never cycled back on, blew the breaker. reset the breaker and soon as i flip the compressor it trys to start then blows the breaker right away.
sounds like its the motor drawing too much current,has it got plenty or oil cause they run low and seize up,not the most reliable can be fine but equally can be dramas especially if its from China
Oct 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps!
Jun 16, 2009 | Air Tools & Compressors
Conversion of 240 v compressor to 120v
take cover off of electric motor where the wires enter motor should have wiring choices there probably will also have to change motor start capacitor
Mar 25, 2009 | Air Tools & Compressors
Converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
Nov 15, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
1,202 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
