Question about Dell Axim X30 Pocket PC
Lost CD Rom for my Axim x30. Anywhere I can download it?
I lost my CD Rom to download the program so I can sync my Axim X30 with my computer. Is there anywhere that I can download this? I have tried the support.dell.com but I can't seem to find the file to download. I don't need the software to upgrade anything, I need the software for the computer to let me connect the two.
  • 22 Answers
You need ActiveSync from Microsoft. Unless you're using Vista which uses Windows Mobile Device Center. Connecting to the Axim to a Vista machine should automatically download the Windows Mobile Device Center software.
ActiveSync for XP and older systems can be downloaded here:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
You'll proabbly still want to update your Axim's firmware and drivers if possible.
Posted on Feb 04, 2009
How do you install downloaded programs on the Dell Axim X30?
Downloaded programs can be installed onto the Dell Axim X30 using Microsoft ActiveSync. Microsoft ActiveSync can be installed onto your computer using the Dell Companion CD which came with your Axim X30.
Once Microsoft ActiveSync is set up on your computer, if the program you downloaded came in an installer file, then double-clicking on the file will start the installation wizard and the software will be automatically transferred to the Axim.
If the program you downloaded did not come as an installer file, then double-clicking it will bring up an error message. In that case, use ActiveSync Explore to copy the program file to the Program Files folder on your Axim.
Mar 05, 2011 | Dell Axim X30 Pocket PC
Lost product key cannot sync to computer am not original purchaser so dell is of no help. Is there some other way of syncing the ax30 to my computer? Thanks
u can format ur format ur pocket pc and then try to synchronize
or synchronize it via downloading third party software such as mobiMB u need the usb driver of ax30 which should be on cd provided with ax30,if not u can download the ax30 driver from net for using mobiMB
Mar 30, 2010 | Dell Axim X30 Pocket PC
Is my Axim X30 compatible with MS Office 2007?
If you save the document in word 97/2000 it should work with the X30 version of word.
Aug 14, 2009 | Dell Axim X3 Pocket PC
I am updating the ROM on my x30 Axim. It has
I am having the same problem and the hard reset will be fine all it will do is remove all the data that you have inputted into it and you will have to re-enter all the information and possibly re-install all the apps you have installed hope this helps
Jun 29, 2009 | Dell Axim X30 Pocket PC
I have an Axim x30 and I am in the process of flashing the bios. Everything went well until it started to copy the new bios to the device. The message came up "lost usb data stream". Now there is no usb...
May i direct you to this site : http://www.pocketpccentral.net/help/dellx3reset.htm
It shows how to soft reset and hard reset your Axim. I believe that after a hard reset your axim shall sync and you should try updating the rom again.
I take it you were using a rom update from Dell?
Best Wishes
Karlos
Jun 28, 2009 | Dell Axim X30 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
X30 time error scynchronization
Have you got the correct time zone selected in the Regional Settings on the Axim?
If you have the time showing on your today screen click on it and you'll be presented with a screen showing which zone you have.
Mar 17, 2009 | Dell Axim X30 Pocket PC
I don't have my cd rom for my axim.
Go to support.dell.com
click Drivers and Downloads
clcik System
Click Axim
Select your model
all software is there ready for downloading
Feb 03, 2009 | Dell Axim X30 Pocket PC
Dell axim x30
HI You have two ways: 1) Install the ActiveSync (Version 4.2 is recommended) PC Software with your PC first Next, you connect your Axim to your PC. Then you install the software or game into your PC. it will also install into your Axim automatically thru Sync process. 2) Or install the software or games into your External SD Memory card thru USB SD Card reader. Then put your sd memory card into your Axim and run the software or game. The 2GB or 4GB SD Card is reccommended since the game or software sometime is huge. I hope it is help. Regards, pingping
Jun 14, 2007 | Dell Axim X30 Pocket PC
Dell Axim X30 Pocket PC Logo
583 people viewed this question
Alun Cox
