Question about Lexmark X1270 All-In-One InkJet Printer
Flashing power button on X1270
I have seen similar problem and tried out all the solutions.
The power button on my printer is flashing in a pattern 1 flash, 2 flashes, and it will not respond when I send things to print anymore. It used to send me a message to take out and put back in the ink cartridges but now I don't have any response at all.
I have uninstalled and reinstalled the driver a couple of times but it does not seem to make a difference.
It was not a paper jam or cartridge change which caused this unusual behaviour, instead it happened spontaneously. I was prinitng something one day and then half way through it stopped and broke.
Please please help me!
  • kv5161998 Feb 08, 2009
    Power button on printer is blinking and nothing will print.
    Scholar:
  • 124 Answers
Go to the following website to contact Lexmark to help you with the solution:
LEXMARK SUPPORT
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this respond!
Posted on Feb 04, 2009
Hi im having some problems my aunt just gave me her lexmark 1250 and the paper keeps jamming i think i have that fixed but now i go to print a test page to see if its working and all i get is a flashing...
The flashing power light could be to a faulty cartridge or the cartridge carrier has stalled. Follow the steps below to fix the problem:
  1. Open the printer cover.
  2. Ensure there is no jammed paper in the cartridge area and the cartridge carrier is free from any obstructions (any foreign objects or debris)
  3. Remove both cartridges from the printer.
  4. Close the printer cover.
  5. Unplug and replug the printer into the power source to reset it.
  6. When the printer turns on, re-insert 1 cartridge first. Close the printer cover.
  7. Check the light pattern on the power. If not blinking, open the printer cover and re-insert the other cartridge.
  8. Replace whichever cartridge is causing the power light to blink.
Hope this information has been helpful.
Jul 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
When I switch on my 1270 the motor runs for some time and then the green light on the power button flashes. If I open the printer the cartridges do not move to the center but they move when I switch off.
I am not sure what the light pattern indicates though but try to reset your printer. Unplug the power adapter(small black box where the power cord is attached) from the back of your printer.
Wait at least 10 seconds before plugging the power adapter back in the printer. Also, check and make there are no paper jams.
Apr 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Of 3 lights: green on right and red in center are flashing, unable to stop them.
How to fix blinking lights Printer lights blink in certain patterns to tell you about specific problems. Read this document until you see the pattern that your lights are making. The solution is below each pattern. NOTE: There may be more than one reason why the printer lights are blinking, so you may see several solutions. PRINT CARTRIDGE light RESUME light POWER light Off Off Off c00106861.jpg c00106862.jpg c00106863.jpg Problem
The printer will not turn on.
Solutions
1. Check the power cord or power module connections at both the printer and the power source (power outlet, power strip or surge protector).
2. Try disconnecting and reconnecting the power cord or power module to the printer.
3. Try reconnecting the power cord or power module to the power source or try a different power source.
4. Verify that the printer is connected to a power outlet that works.
5. Make sure there are no additional switches turned off, such as those on a power strip or surge protector.
6. Check the power breaker to make sure the power source is working.
If these solutions did not fix the problem, have the printer serviced. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09170&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=59129
Dec 09, 2010 | HP DeskJet 940c InkJet Printer
Hi, My Canon Multipass F50 is flashing the "Wrong Cartridge" error message. I have read a proposed solution to get into the test mode, clear the eeprom and input (0) for the ink code. It doesn't have any...
One fellow on fixyourownprinter.com fixed his this way:
85.gif Re: MultiPass F50 by Anonymous (11/4/05 5:35 AM) reply + / - I tried this and it worked great. My F50 kept showing "wrong cartrige." I don't take credit for this I foud it on another sight
for another model of canon printers, but it worked on my used F50.
Here it is:
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
I hope this info helps.
~Kevin~ in Las Vegas
Here is the web blog that talks about this problem:
http://www.fixyourownprinter.com/forums/inkjet/24152
Good luck, hope this helps, and thanks for using FixYa.
Aug 26, 2010 | Office Equipment & Supplies
FLASHING E2
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tonl-i-4
Jul 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Power light keeps flashing
Sound like residue from the protective tape that was on the cartridge. Take the cartridge out and clean the copper contacts with a Q-Tip dipped in alcohol. VERY lite-ly... I have seen a lite glaze from the tape stopping proper contact if the were on the store shelf very long....
Please rate this solution if it helps.... Thank You...
Oct 25, 2008 | Lexmark X1270 All-In-One InkJet Printer
Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
Ink levels/streaky printing
remove the carts & using a wet paper towel, clean the nozzles on the carts to see if your getting any traces of ink. U can also go to the solution center & under maintainence u will fine an option Clean to fix horizontal. try this twice that should also clear any blocks then try this
  • Printer power OFF
  • Hold down the PAPER FEED button while powering the printer ON
  • Release button after powering printer ON
  • Test is continuous, so turn off when printing is complete
If the cart has any ink it will print 3 color lines & a blk line
May 12, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Can`t get my Lexmark X1270 to download on my pc.
When the power button is flashing, try unplugging and replugging the printer. If it still keeps flashing try removing and reinstalling the cartridges. Make sure nothing is obstructing movement of the cartridges inside the printer.
If nothing helps you may need to buy a new printer. Be sure to check first if Windows 98 is supported, because lots of new printers don't support old versions of Windows.
Sep 25, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
101 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
