Question about Equator EZ 3612 CEE Front Load Washer/Dryer
Loud noise in spin mode and black spots
EZ3612CEE While spinning makes a knoking sound real loud then when it is in the dry mode it leaves black like grease spots on the clothes from the drum holes that wont come out.
    Scholar:
  • 99 Answers
This is joyce
How old is this unit?
this can be costly to fix, it may not be worth the cost, may just replace, the barrons in drum sounds like they are shot and the oil is from the inside gasket, my friend at work had the manufacture to replace her dryer because of this. you may want to call them if your unit is not to old, they also may have recall on your unit so call and make sure of this before you discard unit. go to webb site I have never heard of your unit so I am not familar with who makes this unit.
thanks
please grade me at end of session
joyce
Posted on Feb 07, 2009
How can I correct UE error?
I guess you got a Korean washing machine
Ue code is called unbalanced error during spin
Do this if you know what you are doing
Check washing machine if it's fixed well on the floor
Check clothes in drum if they are moved to one place.
Make sure there's no excess foam in the drum
Now if all above are ok then
Set to rinse + spin program and start it
And wait
If it doesn't go to spin speed and you hear a loud knoking noise then u should call service centre
Or if u are a tech then check shock absorbers and
Balancing counter weight .
Jan 31, 2016 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
H300 brushes won't stop spinning even though I switch it from "wet scrub" to "wet/dry pickup" and is leaving streaks on the floor. I have already ordered a new squeege, but that won't take care of the...
Make sure you REALLY pull the lever controlling the brush spin all the way up. On mine I REALLY need to force it to the top. If I don't use enough force and it's just a tiny bit below the top, the brushes continue spinning. I wish it was easier to flip from one mode to the other but mine has always been "stiff". Hope this helps. It took me a while to figure it out. Once you get the hang of using it, it works GREAT!
Jun 11, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Bissell 8990 CleanView Bagless Upright - Loud noise
Sounds like maybe your motor went bad, part # 2031052. Would sell for about $60. When the bearings go bad, they can be real loud as well if the fan on the motor when it gets damaged.
Dec 30, 2007 | Bissell 6590 CleanView Bagless Upright...
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
230 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
