Question about Acer AOpen AX4BS-V (91.89J11.001) Motherboard
I dont know how to hook up the power plugs on motherboard
I had to take apart a computer for class and then reassemble it. I got it all together except i cant remember how to hook uo the 5 little black power plugs. Someone please help me!!!
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Julie,
    Are you speaking of the front panel connector?
    Is your motherboard the one that this is posted under?
    Aopen AX4BS-V?
    I have downloaded the manual, but it is a little confusing getting it. I can email it. If you want to list your email do it as a long form. For example myemailatgmaildotcom. That way spambots will not detect it. If you don't want to list the email, I understand. I will try to give you more info. I also tried to copy the portion of the manual that contains the front panel connector to post here, but didn't have any success with that either.
    Let me know.
  • support210 May 11, 2010
    What do you mean 5 little black power plugs? This could be anything, is this for USB power or the ON/OFF switch power, or the HDD lights display? If the wires that are connected to the "black plugs" are colored, the black plugsshould be marked as to what they are and you should see the same on the motherboard itself next to the prongs. If not, then you may have to do a google search on that particular board, or goto it's manufacturers website and download the manual.
    President:
  • 1,901 Answers
OK, I think I have this for you. Here is a pic from the installation manual.
Forget the email thing, unless you want the manual.
Thanks for using Fixya.
Posted on Feb 04, 2009
DRIVEWAY ALERT MONITOR
Tries to reassemble the plug and rescrews tighten all the screws or supper glue it together again.If the power transformer charger it is a standard A/C plugin chargers,tries places like Walmart,Best Buy,Radio Shack or online shopping too like Amazon.com,eBay.com and the product manufacture too can buy the original transformer charger or a clone one should work too, if charger it have the same A/C input and output of the transformer charger plug in power like Amp,Voltages lable that in the transformer plug in part of the charger.
Aug 30, 2012 | Computers & Internet
My computer was built piece by piece worked just fine Some problem occurred that made taking apart my Computer necessary When I reassembled it it no longer worked. It turns on the fan goes for a sec or 2...
This could be anything from a faulty graphics card, bad power supply or even the motherboard.
What you need to do is disconnect all of the hardware except the motherboard, power supply and memory. Then try turning the machine on.
If it turns on start putting things back one at a time to see which item is causing the machine not to start.
If it won't turn on with just the memory and power supply installed then you either have a faulty motherboard or power supply, but to test these you have to check the voltage on the power supply which isn't easy.
Your best bet would be to get a compatible working power supply and hook that up.
If it still won't fire up then you know the motherboard has come to the end of its life and needs replacing.
Let me know if there is anything else.
Good luck and regards.
Jun 22, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I HAVE A CAR SEAT THAT I TOOK APART IN ORDER TO WASH THE CUSHIONS BUT NOW I DONT KNOW HOW TO PUT THE STRAPS BACK TOGETHER
There is normally a splitter in the back, a metal piece with two hooks that is attachted to the adjustment strap. the sholder straps latch onto this. You can locate the appropriate manual here: http://www.coscojuvenile.com/usa/eng/Instructions The pages in the back normally discuss reassembly after cleaning.
Mar 19, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
Gateway computer 310 series wont power up when
It sounds to me like the power switch is plugged into the motherboard incorrectly. I would need to know the type of motherboard you have to get you the proper schematic for hooking up the power switch and reset switch to the board. If you have the manual to the motherboard, there should be a detailed picture showing you how it is to be hooked up. Please let me know the motherboard model for further assistance.
Good Luck,
NOLA Tech
Jan 29, 2010 | Gateway 310 S PC Desktop
Hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Sep 15, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Computer won't boot or shut off
Yep--you put it together incorrectly.
I don't know why you took it apart. Don't do that again. Just open the case and blow it out--especially the power supply. There is nothing to be gained by taking all the stuff out of it.
I would say you have the little plugs from the front panel in the wrong place. You don't have the power switch on the correct contacts. Your memory might not be seated fully. If you have a video card, it's not seated correctly.
The way to check where those little connectors it to look on the motherboard itself and printed near the little posts where you hook up the plugs. The posts should be labeled as to pwr sw, pwr led, rst, ide led, spkr.
Try that--and good luck. If you need further help, just post it here.
Jul 01, 2009 | E-Machines eMachines Desktop PC
A205-s4607 cant get past bios password
You will need to reset the CMOS/BIOS
Tools needed:
Philips screwdriver
anti-static wristband.(if you dont have one then make sure you touch something metal before touching any circuitry in the computer)
unplug the laptop and remove the battery pack from the laptop. While unplugged press and hold the power button for 5-10 seconds to discharge any power left in the laptop.
(IMPORTANT: Make sure you wear your anti-static wristband or touch something metal before handling the circuitry of the computer)
This is where it will get tricky you will need to open the laptop and look for a battery on the main chipboard(motherboard).Be extremely careful because there will be ribbons connecting the keyboard to the motherboard so take apart the computer slowly. Slow and Steady wins the race here. The Battery will range in size from the size of a nickel to a quarter. You will need to remove this battery. wait about 15 seconds then put it back onto the motherboard where you just took it out from. Put computer back together and plug battery pack in and plug in power and turn on you should be able to access BIOS without being prompted for a password.
You will need to reset the Time and Date of the system in BIOS once completed.
If this is too techy for you then I recommend taking it to your local computer repair shop for them to do for you.
good luck
Apr 05, 2009 | Toshiba Satellite A205-S4607 Notebook PC
Acer travelmate 2300 motherboard problem
Sounds to me u hav not done proper Soldered it onto the motherboard. CHECK THE WIRING AGAIN.
Jul 27, 2008 | Acer Computers & Internet
PC Not Starting
When you say "...put computers back together..." what does that mean?
Check video cable pins. Check disk drive connector...make sure they are pushed in tight on mobo and drive connector.
T
Apr 27, 2008 | MSI 694T PRO (6309-470) Motherboard
Acer AOpen AX4BS-V (91.89J11.001) Motherboard Logo
1,215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
