Question about Emerson Part UWL Chrome Ultrasystem water heater...
NOISE MY WATER HEATER MAKES A LOT OF NOISE WHENEVER I TURN THE WATER ON. IT SOUNDS LIKE THE TANK IS FULL OF ROCKS. IS THIS BAD, CAN IT BE REPAIRED OR DO I NEED A NEW ONE?
  • KORONADOR Feb 04, 2009
    THANK YOU I WILL!
  • 34 Answers
You need to flush your heater..or try to. This is going to be a minreal build you from what you are saying. I advise people to drain there heaters yearly in areas with water that has high minreal content. I hope it is not to late for you. The tools you will need are ; channel locks, and a flat head screw driver, water hose. There will be a faucet on the bottom of the heater. Connect the water hose to the end of the faucet, make sure your hose has a good rubber washer in it or you will have a mess from water leaking. You will want to disconnect the flex hoses from the top of the heater. The will break the vacum and allow the water to flow. You will want to run the hose out side. Try to keep it from going up hill. turn the faucet on. If you faucet does not have a handle and only has a notch you will need to use the screw driver. I hope this will work
Posted on Feb 04, 2009
  • bigslimaba Feb 04, 2009
    Let me know if you need anything else
My hot water tank is making a loud noise refilling after I have run a bath and takes ages to refill
How old is ur water Heater? Ur tank is always full of water, as u use hot water, cold water flows in. R u saying it takes a long time to reheat the water in the tank? Has this always been an issue or is it new? Or has it slowly gotten worse?
Apr 02, 2015 | Water Water Heaters
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Model ee3j50rd045v whirlpool electric water heater is heating fairly well but the diagnostic light turns on and off and makes a clicking noise when doing so. This usually occurs after you run water for a...
The only Whirlpool electric heater I know with control board is Energy Smart electric:
Open following link to identify product and download sample manual:
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
First of all, the water heater is always full of water.
When you turn on hot water tap, hot leaves top of tank, and new cold water immediately enters bottom of tank through the dip tube. The tank never has air pockets as these would damage tank as explosive steam would fill that pocket ... remember they used to run locomotives with steam power.
So the tank is always full of water, and you know that since no air comes out of the hot water faucet.
http://waterheatertimer.org/How-it-works.html
You did not say if this is new heater, or if heater was working correctly and stopped functioning.
What you describe does not sound normal.
I suggest calling Whirlpool at 1-877-817-6750.
You need to have serial number and model number from label on side of tank so product can be fully identified by Whirlpool.
If control board is bad, they will know and will sell you new board.
Installation is easy, and wires are color coded.
Replacement comes with instructions.
Add a comment with your experience so others with same-similar problem can benefit.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 25, 2011 | Whirlpool Water Heaters
My water heater makes hoise what can i do to make it quiter
You posted under electric water heater.
1) Gas or electric, the noise is from sediment build-up inside tank.
Once sediment builds up, the only way to solve problem is to clean the tank out.
2) To restore full efficiency to electric water heater and stop the noise, clean the tank:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
3) To clean gas water heater is more difficult and less successful:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) To prevent sediment problem, flush water heater each 6 months before sediment can build up.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
5) Other things to know for water heater maintenance.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Mar 21, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Seems as though there is a whole in the tank causing wter to spew out, The whole is yhe top of the tank and appears to be very small, can this be patched or soldered?
If water heater has a hole, then water heater is rusted out and must be replaced.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Immediate problem is ruptured tank.
Water heaters are under pressure, and rusted water heaters rupture and water runs until water is shut off.
This causes major damage inside home.
Protect yourself first, and then let's talk more.
1) Turn off water at shut off located on cold water line above tank.
2) Turn off power to water heater:
Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
Electric heater, turn off circuit breaker.
3) Open tub spout on hot side and let run a bit to relieve pressure.
4) Now your property is safe.
You can limp along with failed heater if leak is slow.
Turn heater ON when you need hot water.
Typical Gas heater makes 41 gallons hot water per hour.
Typical Electric heater makes 21 gallons hot water.
Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
If you are going to install heater yourself:
Look at label on side of old tank to identify size and particulars.
I buy ordinary heaters from Lowes and Home Depot and always look at scratch-n-dent models.
Buy same size heater if it worked fine before.
Buy new flexible water connectors.
Set water heater in drip pan.
Offer 10% less than price shown.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit with 1 repair.
2) How to install gas heater:
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
3) How to install electric heater:
Read link above because many of same steps apply to electric.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in a circle so it fits inside dip pan.
Also read:
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
Jan 01, 2011 | Water Heaters
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My water heater is leaking a lot. water comes from the down bellow. It started like three months ago but it is getting worst Do I need to replace it? how much it will cost a similar one?
It sounds like you need to replace it, Actual cost can very widrly depending on your location but I would say $350-400 is probably close. Plus installation unless you can do it yourself. Hope this helps. Thanks
Nov 23, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I purchased a new GE GE50M06AAG water heater at Home Depot. Installation was fairly simple and straightforward. Once the tank was full the T&P valve started to let water come out of the valve, causing...
Hello Put a bucket under the relief valve and lift the lever up and snap it closed.Maybe it is not seated correctly.If not change it out.Also if the new one acts up you need a cold(domestic)water expansion tank(EXTROL) in the cold water pipe.
Sep 17, 2010 | General Electric Water Heaters
Sounds like a squirrel inside water heater
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Mar 25, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Water Heater Repair
If steam or excessively hot water shoots out of faucets, or you hear boilding sounds inside the hot water heater, the appliance may not be shutting off at its set temperature. The job of the temperature- pressure (TP) relief valve is to release excessive pressure from steam buildup, but this valve may have been improperly installed, or it may be faulty. Either way, this condition can be dangerous, both because hot water and steam can scald people and because enough pressure could build up to rupture the water heater. Immediately turn down the water heater’s temperature setting and allow the water to cool.
Aug 27, 2008 | Emerson Part UWL Chrome Ultrasystem water...
Emerson Part UWL Chrome Ultrasystem water heater... Logo
95 people viewed this question
Top Emerson Water Heaters Experts
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
