Question about Kenmore 24982 Top Load Washer
Trouble with the spin cyle.
I have a Kenmore 24982 top loading washer. It will run through a wash cycle without a problem, but when it goes into the spin cycle, it will start out slowly and then stop. It will sit there humming for a while (an electrical hum, as if it has overloaded a circuit breaker), and then try again only to repeat the humming cycle. Occasionally, if I start the whole process over again, it may run through all the cycles completely, but that is becoming rare. I put a power strip in line with the electrical cord to plug in a small light in the laundry room, and when I ran the washer it tripped the breaker on the power strip. It must be drawing a lot of current. Any suggestions?
  • Kenmore Master
  • 8,220 Answers
Bad motor. Easy to replace. Worth the effort.
To find out how, click HERE
Posted on Feb 05, 2009
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Won't spin at end of cycle
POSSSIBLE BAD LID SWITCH OR DRIVE MOTOR TO TRANSMISSION COUPLING IS BROKEN POST MODEL NUMBER PLEASE
Apr 17, 2009 | Kenmore 24982 Top Load Washer
WASHING MACHINE
washing machine goes through whole washing cyle without draining.
Nov 07, 2007 | Frigidaire GLWS1339CS Top Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Rinse cycle spinning... clothes still soaked
It sounds like your washer is not going through it's neutral drain. After agitation, your washer should pause and drain for around 90 seconds to pump out the water before spin. Check this out by starting a wash with a small screw driver holding the lid switch down. This will allow you to observe whether or not it's going through it's neutral drain. If not, it's a transmission problem. The trans is covered under warranty for 5 years. You may also want to check the pump to see if it's gunked up. Catriver..post back.
Dec 04, 2006 | Kenmore 24982 Top Load Washer
Kenmore 24982 Top Load Washer Logo
111 people viewed this question
Sal De
fordexpert
Robert Rankin
