Question about Kenmore 42924
Washer fills with water when the machine is not running
I have a Kenmore Elite HE3t 42924. Occasionally it fills with water when the machine is not in use. Not sure where the water is coming from. Any suggestions?
  • 413 Answers
Either the hot or cold water valve is not closing completely. In either case, the mixing valve assembly will require replacing.
Posted on Feb 04, 2009
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
It starts to fill with water than stops to soon and the motor is just running
my Kenmore He3T Stop But Remain have water on the bottom!!!
What happen
Oct 08, 2012 | Kenmore HE3T Washer
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
When the washer is not running it is slowly filling up with water. Kenmore Elite HE3T.
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
May 08, 2010 | Washing Machines
Kenmore Elite HE3t washer tub filled with water when machine was off. Do we need repair? Was it just a fluke?
Hello, sounds like there was a blockage in the inlet valve. May have been a piece of calcium. I would run the machine a few times if you have no other problems don't worry too much. If the machine starts filling again pull the plug if it shuts down you have a problem with the machine. if it continues to fill there is a problem with the valve. You should replace it. Mike
Oct 26, 2009 | Washing Machines
Kenmore elite washing machine spin cycle slow. The clothes are still dripping wet when removed from the washer.
In my HE3T, this was indicative of the water pump going out. In its 8th year, my HE3T is now on its 3rd water pump.
Aug 02, 2009 | Kenmore Washing Machines
Kenmore elite he3t washer
remove fill hoses at wall and washer ends look for a screen in hose at faucet end and 1 in washer fill valve pull and clean them be sure to reinstall screens before reconnecting..also fluch hoses out after reconnecting to faucet end and before reconnecting to washer to flush any trash/sand that be in them
Aug 15, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
91 people viewed this question
Sal De
fordexpert
Robert Rankin
