Question about HP (152769-001) (152769001) 250-Watt Power Supply
Updateing power supply
I want to update from 250 power supply to 650 supply..Any problems.
  • George Bill
    George Bill May 11, 2010
    u can't udate a power supply, you need to replace it, is that what you mean
  • 679 Answers
As long as it's the same type, there should be no problems, you will see more stability with a larger power supply. The board is only going to use what it uses anyway, but down the road if yo plan on running SLI or something like that it will come in handy. I have 450 in mine and run 2 video cards. Your power curve will be flat, in other words no voltage spikes. good luck
Posted on Feb 04, 2009
    President:
  • 948 Answers
Make sure you have the right connector(s) on your new power supply. The main one is 20 or 24 pin, and several four pin. Double check what you have now and make sure your new one has the ones you need.
    Sergeant:
  • 219 Answers
You will have to figure out if your current case is ATX or Micro-ATX. Afterward find a power-supply online that will fit an ATX or Micro-ATX case. Another factor to consider is your motherboard's power connector. Some motherboards can only take a 20 pin while others take a 24 pin.
Perhaps a good power supply choice would be a PSU that has a 20+4 pin motherboard connector.
You can find some good Power Supplies online here. Just use the navigation menu at the top and go to: Computer Hardware>Power Supplies. After select, "Power Supplies" on the left and you will be able to find PSUs for desktop computers. I recommend the PC Power & Cooling brand, they are extremely reliable. Some of their PSUs also offer the 20+4 pin connectors.
Remember, it must fit your case and must fit your motherboard! Have a great evening.
How to update the software of philips SW9810
There is no firmware for this model. Yu can check yourself on this link.
Find your product
For every update there is a condition, the electronic needs to work perfect and the battery / power supply must be capable of delivering enough power during the whole update process.
When an electronic device is start acting strange, a software update is the worst thing you can try to solve the problem.
Aug 02, 2014 | Philips hts3540/98 code free dvd home...
Where can i find an firmwareupdate for benq dc c850
Please.
Updates are only allowed if the system is working without an error.
If it is not working correct, you can't be sure it will load the update correct and you never know what happens when the update is started.
I'm sure there will be no update for the Benq camera.
Jul 27, 2014 | BenQ Cameras
Coby phone firmware update
Al firmware updates come with an instruction.
I hope you did read the instruction, before you updated in the first place.
If there is an update for your phone, why should I type the instruction here? it is in the package and you should read it before. not when the phone is bricked.
Jul 25, 2014 | Coby Lands Phones
How update firmware?
Please.
External drives are so simple, they hardly ever need any peat. If they need one, you can find it on google. And the firm will send mails to any registered user.
With any firmware update, more warnings coe than I can write down here. If you have a problem, look if there is an other way to solve this.
Jul 18, 2014 | Iomega MiniMax Desktop - Hard drive - 500...
How to solve the dlink 605l router restarting problem ? my firmware is upto date.
It could be:
  • Overheating. Make sure the space around the router is clear of obstructions
  • Faulty power supply/power source. Try a different wall outlet, Check that the power supply is not super hot.
May 28, 2014 | D-Link Computers & Internet
Facebook pages wont load I am using windows xp
Update browser, update Flash player, update Shockwave. If still nothing, you may need to add a Java Runtime Environment- or update your existing one.
Apr 07, 2012 | Dell Dimension 5000, 5100, 5150 Power...
I jus left my computer optiplex gx260 on and when
Your automatic update from microsoft probably updated your machine and shut it off, by default it is set to update if their is one, every tuesday at 2:00 or 3:00 am and will either restart or shut down your machine.
if thats not it then your computer may have gone into hibernation or standby.
May 25, 2010 | Dell POWER SUPPLY Power Supply
My windows alwyas restart & recovery bios
orangmedn
pc r restart for several reason like power supply problem, over heated, os problem. if ur pc restart when u try to access any drive or insart cd or dvd in drive means ur power supply is faulty. and if it restart after a fixed time (approximately) means over heated. (u reinstall xp so operating system is not infected.) if one of above symptom r their then no need to update bios.
2nd if some problem heppen during ur bios update and it not wirte properly and u restart ur pc in this situation the ur pc can not start and result is no display condition. if it happen then contact with any mother board repear centre or mother board service centre. (because if bios program r corrupt it need to repalce or rewite).
(**2nd time if u update any BIOS be Cautious. at first take backup then update. if any problem happen then restor with backup copy, then restart ur pc. until u sure update successfully do not restart ur pc).
Jul 10, 2008 | MSI PM8M-V Motherboard
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
ASROCK 845 BIOS PROBLEM
Hi, This problem sounds more like a failing poewr supply than a bios problem. Can you use a multimeter? If so then check the voltage output from your power supply. The red wire = 6v+or-1v. The yellow wire= 12v+or- 1v. black is negative. If you are not sure then try a different power supply. Goodluck mistyman
Sep 14, 2007 | Asrock P4I45GV R5 Motherboard
HP (152769-001) (152769001) 250-Watt Power Supply Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
