Question about Toshiba 28N33 28" TV
Toshiba 28N33B This television will turn on but then all it does is count down from 5.00 minutes to 0 and then turn off! Can you post me a manual or tell me how to start it. I am not sure if it is the remote but tried fresh batteries and bought universal remote and this won't work the tv either
    Problem Solver:
  • 18 Answers
If micro and eeprom have changed and still faulty, the your problem might be the infrared receiver ggod luck.
Posted on Jan 31, 2008
    Genius:
  • 1,074 Answers
Your problem is in the microchip and eeprom have both change,this will stabelize your tv.good luck.
Posted on Aug 05, 2007
SOURCE:
Drum life warning on toshiba dp120f
reset drum Counter for DP120
Turn fax off. Hold down 0, 1, 3 on numeric key pad and turn fax on. Then release the 0, 1 & 3 and enter the number 80, wait a few seconds and should see a message confirming counter has been cleared. Then turn fax off and on again
Jun 21, 2012 | Toshiba e-Studio DP170F Plain Paper Laser...
What is the code to sync up with a sky remote
Hello
Sky remote codes for Toshiba TVs are:
Toshiba
28W93B 2563DB
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
Toshiba
156T9B 175T9B 213T4B 2151TB 2197DB 2512DB 2535DB 2539DB 2550TB 2563DB 256T9B 28Z27B2 2812DB 2857DB 2835DB 2873DB 2877DB 28W93B 2500TB 3357DB 573DB 2879DB T1510T8 25001TB7 32DB 32M8DB 2855DB CT9689 2939DB 40PW03B MV40PWA 32M9DB3 2893DB 32317B 2573DB 337BB 2552D 36/21P 28207B 2173DB 285T8B 2173DB 28W8DBA 28N03B 2505 238DB 439J936 3377DB 2181TB 82Z27B 28W23B 32ZP18P 42PW33P 32NW2DB 28ZH37B 32W8DB 32ZP38B 32NW7DB 32WIS 28N33B VTV1400 2987DB
536
Toshiba
2101TB 213T4B 2573DB 32ZP38
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
2987DB 3339DB 2877DB 322D09B 2173D6 14N21B2 14N21B2
063
Toshiba
14T01B, 21TO1B, CT815, CT81500082B, CT824, CT832
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
OK.
Oct 13, 2011 | Toshiba Televison & Video
I disconnected my TV when we were having work done in the house. At the time I had no trouble getting Sky. A new connection to the dish has been installed but I cannot get onto Sky. I have checked the...
Hello
To synchronise with sky you have to resynchronise it, as you have disconencted it and reconencted with new one. The sky remote codes for Toshiba to check with are:
28W93B 2563DB
Toshiba
536
Toshiba
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
Toshiba
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
063
Oct 05, 2011 | Toshiba 32WLT58 32 in. LCD Television
Turn tv on. no signal come up, counts down from 5 to 0 minutes help!
The capacitor on your power supply circuit damage causing your tv get off in shot time. Just check it and replace with new one.
Regards,
Jan 21, 2011 | Televison & Video
580ex off camera shuts down after a minute or so of standby
No and no, the flash is by default programed to shut off after 1 minute .If you were using the flash on-camera, the flash would automatically power itself on when camera activity is detected but when the flash is detached, it doesn't wake back up.
To change this you have to turn off the auto shut off in the flash menu:
1. Power the flash on
2. Hold down the back light /C.Fn button until "Fn 00 0" appears on the screen
3. Rotate the selector wheel until you see "Fn 01 0"
4. Press your selector button down so that the 0 begins flashing
5. Rotate your selector wheel to change the 0 to a 1
6. Rotate the selector to the "Fn 14 0" position and set it to 1
7. Press your selector button to save this parameter
8. Press your Mode button to return to the main screen
Now your flash stays on as long as the flash switch is turned on ON, and as long as you have juice in the batteries.
Do not forget to turn off the flash after you are done.You can reverse it anytime, but you have to read the manual for that..
Same setup can be found in the manual
May 07, 2010 | Canon SPEEDLITE 580EX TTL Flash
I have a Toshiba DLP Projection TV model # 44N HM84 made in October 2004. When we turn it on the green light blinks about sis or seven times then turns red. The TV doesn't come on. Any ideas? thanks in...
It is an error code. Count the flashes and then re-post asking what the amount of flashes means and how to repair it. Make sure you post make and model of TV.
Dec 03, 2009 | Toshiba 44NHM84 44" TV
Total Control Remote Code for Toshiba 28N33B TV
TRY ONE OF THESE CODES HOPE IT HELPS. - 018, 028, 083, 165, 205, 245,270, 279, 281, 370, 437, 446, 455, 456, 0R 471. IT WILL BE ONE OF THESE BUT UNSURE WHICH ONE IT IS SO TRY THEM ALL PAL. IF THAT FAILS BUT IT SHOULDENT TRY THIS DEFAULT CODE 042.GOOD LUCK
Jan 22, 2009 | Universal Remote Control NspireGear MP3...
Connecting a wii to a toshiba tv model no. 28n33b
I was having exactly the same problem with my toshiba 28N33B until 2 minutes ago! I searched the internet for the solution but only came accross your unanswered question, i hope you've sorted it by now anyway as its been 6 months, but for all those with a similar problem:
You cannot connect your wii to AV OUTLETS only INLETS! At first glance it appears that the 28N33B only has outlets....BUT actually, the AV inlets are (stupidly) hidden behind the speaker to the right of the TV screen (as if you were looking at the screen) - they are separate from all the other ports at the back of the tv.
For anyone looking for Toshiba inlets on other models - my advice would be to take a deep breath, push the telly out from the wall and take a GOOD long look all over the tv for three circular ports coloured red, white and yellow that have the words 'in' or 'inlet' etc printed near to them. You're wasting your time trying to connect the wii via the audio output, it just wont work, no matter how much you re-tune the tv (I know from experience! grr!)
Right, i'm off to play mariokart, hope this helps somebody!
Sara
Aug 10, 2008 | Televison & Video
Our sony tv keeps turning itself on stand by. you press the standby button on the remote and it comes back on for a few minutes then does the same again until it will not turn back on. you have to then...
When the Sony shuts down, the standby light shoulb be blinking a repeated count. Can you please post the model number and that count? The count will indicate the circuit that had a problem causing the set to shutdown.
Thanks,
Dan
Jul 24, 2008 | Televison & Video
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Toshiba 28N33 28" TV Logo
462 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
