Question about RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds
Car stereo has power but no sound.
New stereo in stalled in dodge caravan. I have made all the conection useing connect product. I have the solid blue open which is the power ant.which it dosnt have and a blue white which is amp mot sure where this goes!
  • pskopp2 Mar 18, 2009
    I have a toyota camry 2001 driving down the road and all of the sudden no sound, change the chanel thinking it is the station still no sound, put in a cd, still no sound. I checked the fuses in the car they are fine, the stereo lights up but suddenly no sound. Does anyone have any ideas
Remove headunit and check if everything was installed properly. check if the fuse on the headunit isnt blown out. check wiring for speakers, for example for some reason they became loose.
Posted on Jul 03, 2009
Hi, i have a 2004 dodge ram 1500 with the infinity stereo system. The factory cd player broke and i tried to install a new cd player, i bought the right wiring harrness and conected it. But the speakers...
it sounds like you need to turn on our amplifier. this is simple and easy to do just by connecting the blue/white wire off of the back of the radio to the blue wire on the harness that connects to the factory harness.
Jul 02, 2011 | Car Audio & Video
I need a wireing diagram for the sterio for a 1997 dodge caravan
Will the color code do, or do you need the actual wiring diagram?
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
Right Rear Speaker Negative Wire (-): Blue/White
Sep 22, 2010 | 1997 Dodge Caravan
1999 dodge caravaAfter installing a new stereo, I found that when
This should be located at the back of the fuse panel. There may also be a relay under the hood in the relay/fuse box. Check those as well.
Also, check the fuse in the back of the stereo (if equipped). If it's blown, replace with new one 2-5 amps higher than original. This may be the problem as the stereo may be drawing too much power. Also, make sure that all wired that may be or are connected to the batter (pos +) are in good repair and have a clean solid connection.
Do this for the ground at the battery as well as the chassi or block. Check also the pos + on the starter.
Please let me know if you need any further assistanve.
carsandcomps
Guru, Premium Expert @ Fixya.com
May 07, 2010 | 1999 Dodge Caravan
Changed Radio - now speakers don't work. I took out the Chrysler radio that had a CD and cassette in it and replaced it with an aftermarket radio. Now the speakers don't work. I got the adapter from a...
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
Jan 19, 2010 | 1994 Dodge Grand Caravan
BUTCHERED WIRING.
Dont know what year you have but one of these will work. Ground is usually separate in Dodges:
1990 Dodge Caravan Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
2003 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Gray/Red
Car Radio Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Chassis Or Metal Strap
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Jun 02, 2009 | Car Audio & Video
Radio schematic
1996 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
May 29, 2009 | 1996 Dodge Caravan
Tuner works but when cd or i-pod are selected they indicate theyare playing but no sound.
Is your stereo sytem amplified? if so then the remote turn on wire may be hooked up to your power antenna turn on wire. The amp needs to be connected to blue w/ white strip.......not solid blue. The solid blue turns off to lower a power antenna when the tuner is not in use. Blue with white always stays on with tuner cd or ipod.
May 23, 2009 | Car Audio & Video
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
May 16, 2009 | Jensen MCD-9424RC CD Player
Dodge radio starts then shuts off
Hi Davis,
I had the same problem with Dodge Grand Caravan as well. I have a 2001 GCV and these radios go out all the time, plus each speaker has separate amps which some speaker will stop working. You will need a new stereo, however the dealership will charge you over $350 for the same replacement. I chose to go to BestBuy and buy a new Stereo for around $100 which has iPod connections which is a plus.
Next problem!!! Since each speaker has its own amp, in order to get the new stereo to work, I had to install a relay by tapping into the passenger side kicker panel master amp power supply to bypass the chip. Best Buy guy will know what to do. I suggest install the stereo yourself with a kit and go back to install an amp bypass relay switch. Hope that helps.
Stock Stereos **** and Dodge make is difficult to go aftermarket.....Good Luck
Apr 05, 2009 | 2001 Dodge Grand Caravan
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds Logo
4,122 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
