My canon copier PC-745 won't power up it has error code EO
The page came half way out then stopped then a code EO came up on the indicator. I pulled the page out of the copier. the copier will not power up only the EO comes up thats it.
  • Anonymous Mar 12, 2009
    My copier flashes EO then 7
    Problem Solver:
  • 8 Answers
I think the problems is in the delivery roll,the rubber is need to be change with the new one
Posted on Feb 04, 2009
Error code eo
Hello Gary, I am happy to assist you! I see that your Frigidaire dishwasher is displaying error code EO; however, is it possible that the code is missing a number or character(s)? Typically error code "E0" is follow by another number. In the meantime, you can reset your dishwasher. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display "EO"? With this information I can better address the issue at hand. Thank you! - Z
May 20, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I get an error code of EO2506 on my W8200. Any ideas?
EO 2506 = No Black Ink Tank or the tank not set properly try to pull it out and put it back again
May 24, 2011 | Canon Office Equipment & Supplies
Code EO is showing on copier
E0 is a fusing unit error code. The fusing unit is the part that heats up and "fuses" the toner onto the paper. It is located right where the paper exits the machine. If this was where your jam was located then there was some damage to the fuser.
The problem is a replacement fuser plus installation will most likely cost you more than you can just replace the machine for. I would estimate you cost at around $200 to $250 to repair.
Good Luck
Feb 25, 2010 | Office Equipment & Supplies
After a power down the range keeps coming up EO F2? I have reset using the OFF/clear button. Oven lights but trips off to EO F2
Hi. This code is an indication of a Shorted keypad (also called touch pad)
Follow the steps below to address this issue further.
1. Check keypad connector for firm connection (keypad connects to control board, via ribbon cable). Make sure the connection is sound, and not severed.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models may incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Dec 04, 2009 | Kenmore Kitchen Ranges
EO code illuminates when power button is pushed, then immediate shut down
Check the fixing thermistor and thermofuse.This code indicated a malfunction in the mai power and fuser unit section.You have one shortcircuit or open circuit in this parts.
Aug 28, 2009 | Canon PC-735 Copier
EO appears at switch on then machine switches off
EO is a error code. You have a problem with the fixing unit. You will most likely have to replace the Upper Fuser Unit....
Aug 21, 2009 | Canon PC-860 Black and White Copier
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
Jun 01, 2008 | Kitchen Ranges
Eo-10 code
hi im jules_09,no the copier is not dirty or jammed,if there is a paper jam it will indicate paper jam there is no error code for that,if the copier is dirty you can see it in the print.reset the error code in the program,if the error code is still there checkfusing unit then the optic sensor
Nov 02, 2007 | Canon PC-940 Black and White Copier
460 people viewed this question
jasbo
jasbo
