Question about Whirlpool Duet GHW9150P Front Load Washer
Something caught between the Tub and asket. How do I get access?
It appears that something has slip through the basket and is caught on the tub wall between it and the basket. There is a loud click every time the ribs on the inside of the basket passes it ( 3 per revolution ). Is there a way to access the space between the tub and the basket without removing the tub/basket asm and then seperative the tub?
  • Anonymous Mar 17, 2014
    there is something caught between the tub and the basket
  • 640 Answers
Iots only 1 trick i know..taking that this is a piece of clothes..take the bottom front panel off..ane remove the tub to pump sump hose,,that will give you a 4 to 5 inch hole to work form..try and push what ever it is towards hole...onthejob
Posted on Feb 07, 2009
Whirlpool Duet Model #WFW 8300 SW01 (noise in drum on high speed-sounds as if it has a chain or something inside rattling. How do we get a manual or parts book?
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite oasis he has a rattle inside when starts to spin and when it slows down. sounds like loose change but i cant see how the money could get between the inner walls. unit is 2 years old.
the rear tub.
and tub assembly.
May 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My whirlpool duet sport is going through a wash cycle and sounds like there are hundreds of rocks in it.
the rear tub.
and tub assembly.
May 11, 2010 | Whirlpool AWM8143 Front Load Washer
11027062600 KENMORE ELITE problem. Sounds like a popcorn machine. Kids wash coins and so forth. How do i get them out?
the rear tub.
and tub assembly.
Apr 03, 2010 | Kenmore Elite Professional Style 51423...
Kenmore he3
the rear tub.
and tub assembly.
Feb 07, 2010 | Electrolux AWF1235 Front Load Washer
I have a Whirlpool duet washer. It sounds like
the rear tub.
and tub assembly.
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do I remove the back panel off Kenmore Elite Dryer
the rear tub.
and tub assembly.
Sep 26, 2009 | Kenmore Elite 45986 Front Load Washer
Lost jewellery in washing machine
the rear tub.
and tub assembly.
Jun 07, 2009 | Washing Machines
Accessing inner drum, potential 'soap ball ' in there
the rear tub.
and tub assembly.
Apr 07, 2009 | Washing Machines
Helpp
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
188 people viewed this question
Dan Webster
Dan Webster
prem mathew
