Question about Panasonic KX-TG1033S Cordless Phone
Cannot redial from the cid list if the # shows an area code!
When someone calls my phone and I don't answer, the callers phone # is listed on the cid list with a 1 then area code. If I call that # from the list the call will not go through. How can I receive calls without area codes. I called
the local phone co, they said it was in my phone and not their equipment.
I have this same problem and am very unhappy with this system because of it. I've had Panisonic before and never have had this problem. I'd return the phones but it's been more than 2 weeks.
Posted on Feb 07, 2009
My Dect 3135 handset is flashing and shows New CID 1. How do I get rid of this and stop it flashing?
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls.
The phone saves the information for the last 50 received calls to the CID list.
The NEW icon marks any calls received since the last time you checked the list.
To open the CID list press CID.
Highlight a number and press MENU/SELECT.
The options:
Delete an entry - this will erase the number from the list.
Store Into PB - this will add the number to the phonebook.
Delete All - will erase all numbers from the list.
Jan 04, 2018 | Dect Lands Phones
The Base says new cid:34. How do I get it back where it was. I tried to get a number that rang and it changed the settings
Julie,
Sounds like 34 is the # of calls that came in on the caller ID (CID) lis
To open the Caller ID list, press the little phone handset symbol (it looks like a big "C" then ID next to it) on the right side of the 4-way button (it toggles 4 ways, so press to the right side to get the Caller ID list).
The phone will show the number of new calls (or Caller ID records) and the total number of stored CID records. Use the "up" arrow and "down" arrow to scroll through the list.
It looks like you have the Uniden DECT 6.0 6035, so I attached the manual in case it helps.
You can set up the answering machine if the voicemail was deactivated by Lifeline (page 38 in manual shows how to set up answering machine). If 4 rings is not enough, you can change the # of rings (page 40) and to use the answering machine/voicemail, see page 42 in manual.
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
How do i delete previous calls from my call display
To open the caller ID list, press CALLER-ID/RIGHT (cursor-right on the circular cursor pad).
To open the redial list, press REDIAL/PAUSE.
Use cursor-up/down to select the desired entry and press MENU/SELECT. Select "DELETE ENTRY and press MENU/SELECT. In addition, in the caller ID list you will have the "DELETE ALL" option.
The above are from the "Using the Caller ID and Redial Lists" section of the manual (page 11 in my copy). If you need a manual, you can download one at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf
Sep 19, 2011 | Uniden DECT14803 Phone
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
KX-T7730 HOW TO REDIAL 10 LAST NUMBER AND 10 LAST NUMBER WHO CALLED ME
If your system is a TA-824 or higher and you have Caller ID, you can set a button that will capture the CID of the last calls you have answered on your set. The feature is called Caller-ID Personal and it requires 2 left side buttons on the phone to be preprogrammed for that feature.
Label them CID-S and CID-I. I put them on buttons 11 and 12 (counting from bottom to top) in the S and I order. To do that, press PROGRAM the button and dial 7 STORE for Indicate and 6 STORE for Select. Now, when a call comes in, it will save under the buttons and you can view them with tie I and S buttons and the navigator up and down arrows.
Carl
Feb 27, 2011 | Panasonic KX-T7730 Corded Phone
How do I get calls(caller id) to show up on LCD?
Panasonic systems require 3 things for CID, 1. CID service 2. CID hardware 3. System programming.
Once you get all 3 things, you'll have caller id. There is also some set programming to log and list calls that is found in the Operating Manual for your system.
Carl
Sep 03, 2010 | Panasonic KX-T7633 Corded Phone
I cannot go down my list of who has phoned
Press the 'CID/FLASH' button to review the telephone-numbers of those who have called you.
Then, use 'UP/DOWN' to scroll through the list of callers.
Set the Panasonic to answer after *EIGHT* rings -- after *FOUR* rings, SaskTel's voice-mail will "answer" the call. So, there will not be "fifth" and "sixth" and "seventh" and "eighth" rings, and so your answering-machine will never get a chance to "answer" the call.
Jun 05, 2009 | Panasonic DECT 6.0 Expandable Cordless...
Area code
I had the same problem with my phone. Tried a lot but couldnt fine the solution.
Aug 06, 2008 | Innovage 1502084 Corded Phone
Shift 3 Talking Caller ID LCD Touch-Panel Phone
I have just purchased the Shift3 Talking Caller ID Phone. For some reason, the talking caller ID function does not work, i.e., no announcement is made identifying the number of the person calling. The "Set 8 Speech" is set "on". Any suggestions to getting this to work?
Jun 20, 2008 | Innovage Touch-panel Phone 1502084
Panasonic KX-TG1033S Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
