Question about Bunn GR10 Coffee Maker
Difficulty in inserting the plastic deliming tool in bunn coffee
The plastic deliming tool won't go in my bunn coffee maker. Doo I need to angle it or what/
Take the 2 screws out underneath where the hole is. the part will pop off and reveal the tube. thats what i had to do. hope this helped.
Posted on Sep 24, 2011
  • paula Sep 25, 2011
    FYI, also.... the hose/tube was never clogged on mine. when i opened up the coffee maker, it was completely clear. I firgured out that the hose was lose. (not completely detached), but just pulled away a little...enough to let air in and so it wasn't drawing right. kinda like when you have a hole in a straw. it won't work. Anyway, I sealed it better. no big deal....and it works absolutely perfect again.
  • 131 Answers
Try keeping pressure on it, and turn it around as you insert it. You are trying to go around a corner in the tubr, and sometimes it is hard to get it to go around the bend.
Posted on Feb 10, 2009
Coffee machine every slow
Water discharge tube from heated tank is likely caked with mineral deposits. Bunn makes a de-liming tool for just such a problem.
Google "bunn deliming tool", or buy it on Amazon.
Bunn Deliming Cleaning Spring 01193 0000
Jul 25, 2014 | Bunn 10 Cup Home Coffee Brewer
Bunn CW series slow water flow
delime the sprayhead and the reservoir drain in the top with a deliming spring or a screwdriver
Dec 03, 2012 | Bunn CWTF 15-3 Coffee Maker
How to descale Bunn CW15-APS coffee maker
delime the sprayhead and reservoir drain (in the top) with a deliming spring or a screwdriver. to delime the tank, put a half gallon of vinegar in the top and catch the hot water as it comes out of the sprayhead. leave it sit for about 20 minutes and brew at least 8 times (w/o coffee) or until you can no longer taste vinegar
Jun 20, 2012 | Bunn CWTF Coffee Makers & Espresso...
Lime in coffee pot
We recommend cleaning your machine with white vinegar for 2 hours and then using the metal deliming tool under where the sprayhead is located. IThen flush it out with 8-10 decanters of water. If this doesn't fix your problem, please call customer service at 800-352-2866 with the model and date code.
Jul 20, 2010 | Bunn 10 Cup Home Coffee Brewer
Slow slow
Please call Customer Service and the correct deliming tool can be sent to you.
May 04, 2010 | Bunn NHB Coffee Maker
My Bunn is taking forever to brew and the coffee
It sounds like the thermostat might be allowing the water to boil and cause the grounds to be scorched and making your coffee bitter. It also could be caused by the machine needing to be cleaned and delimed. I would recommend you do this first-and if you don't have the use and care manual, you may call Customer Service to have one sent out or access one at www.bunn.com @ home, then products.
Apr 09, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Bunn perks coffee very slow?
This is generally an indication of a lime build-up in the water tubing. If you take off the sprayhead and insert the metal deliming tool into the water tubing all the way leaving out about 1-2 inches and twist it about 5-6 times, this should remove the lime deposits from the water tubing. Then flush out the machine with 2-3 decanters of water. If this doesn't fix the problem, then call customer service with the model and date code for further assistance.
Aug 01, 2009 | Bunn GR10 Coffee Maker
Bunn GR10 Coffee Maker Logo
728 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
