Question about Frigidaire GLEQ2152ES Electric Dryer
Front load frigidaire will run for 10 sec and shut off. Help.
I had a tech out but he could not solve the problem.
  • Anonymous Feb 05, 2009
    Same Prob, runs for a second then turns off, no error code.  Prior to this problem - last week I had the problem where the dryer runs but doesn't heat up.  Tech came (is under extd Lowes warranty) and replaced heating element, worked for 1 week now this new problem.  Drum does seem tough to turn.
  • Frigidaire Master
  • 8,220 Answers
Reach inside the dryer and turn the drum. Is it difficult to turn? If so you may have bad glides causing the motor to shut down. Or maybe you just have a bad motor my friend.
Posted on Feb 04, 2009
Have a Tahoe 7000 diesel ,runs great except when you turn on breaker with no load. runs about 7 to 10 seconds and shuts down, Can you help
Hello dear, have you found any effective ways to solve your problem? If you haven't, visit this website to know more information about generator tech.
Generator Set Diesel Generator Cummins Volvo Perkins Generator
Sep 06, 2017 | Chevrolet Tahoe Cars & Trucks
Frigidare affinity stactable front loading dryer. runs for 10 to 15 seconds then shuts off. plenty of exhaust air. it has heat inside. tried resetting to factory specs but still have the same problem
Good Morning Percy, thank you for your inquiry!
From the information you have provided you Frigidaire dryer runs for 10 to 15 seconds and then will shut off. It sounds like it could be a possible problem with your thermostat or control panel. A reset may help with any internal miscommunications inside of your dryer. You can reset your dryer by disconnecting power from it for at least ten minutes. If that does not help your issue I would recommend having a professional technician out to perform an accurate diagnosis on your dryer to avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Aug 12, 2015 | Frigidaire Affinity Series Stackable...
Affinity dryer model FAQE7001LW0 OVERHEATS AND SHUTS DOWN
Therm o resistor or air ducts venting needs clean out
if not that change main board
Aug 13, 2012 | Frigidaire Affinity FAQE7001LW Electric...
Frigidaire top load washer that keeps shutting off
i canty be 100 percent sure
without the model
but it sounds like you motor is trying to start but for whatever reason is cutting out on the overload. Meaning it gets hot,,,and shutsd it self off to save it self
ther ecould be alot of reasons for this,,, far to many to type here,,,
with frigidaire it could be a bad motor capacitor, or a bad start winding on the motor.......
or a simple as a sock between the tubs preventing the tub from truning
sorry i cant be more help
but figured you should have some sort of answer to at least5 investigate
Oct 28, 2009 | Washing Machines
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer starts but then stops after about 10 sec.
You might have broken impellers inside the pump. You should replace it
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
LOC message on display - Frigidaire - GLTF2940FS0
You have accidentally locked the machine. Hold the "Options" button and the "Select" button simultaneously for 10-15 seconds and you are goog to go.
Sep 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Front load washer
check holes under cover for obstruction in dispenser drawer. then check valve operation. there is a handy diagnostic for this. find techsheet on wall on lower left side. set dial to touch up, make sure all leds are off, then press/hold pause/cancel and options within 5 secs of turning off. refer to tech sheet for dial functions, each dial positon back turns on different function.
Apr 23, 2008 | Frigidaire GLTF2940ES Front Load Washer
Perhaps the water valves are defective.............
Dec 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLEQ2152ES Electric Dryer Logo
102 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
