Question about Black & Decker V9650 DustBuster Handheld Wet/Dry Vacuum
Charging Black & Decker Dustbuster
I received a Black & Decker 9V wet/dry dustbuster for Christmas, but it has no instruction manual. I put it in the charging base and plugged it in, but it never seems to have a charge. How do I tell if it is charging/am I doing something wrong?
  • Anonymous Mar 22, 2014
    take apart
  • 328 Answers
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Posted on Mar 07, 2009
Can I fix model cwv363004 black &decker
Hi-
This dustbuster does not have internal parts still available to replace. This model currently still has the filter, wet deflector and crevice tool available. If you would like to locate a service center for further information you can follow the link to find your nearest service center. blackanddecker com
Thanks
Black + Decker Customer Care
Feb 21, 2015 | Black & Decker 15.6 Volt DustBuster Vacuum
Tip
Hi sebo parts can be ordered from sales@gwhitedist.co.uk a good price they will...
Own a Sebo Automatic X1 Bagged upright or perhaps a Windsor-Sensor model? Here are a few tips to get more out of your machine.
When it comes to filter replacement, the standard cone/tube shaped filter can actually be cleaned by the Sebo if only just for a short moment just to get rid of any attached dirt the filter has accumulated. By removing the filter tube, the auto stop clip comes down, but by lifting your finger with this clip upwards and your other hand holding the bin door, the door can actually be locked back into position as it would normally. Then using the standard upholstery t shaped tool, clean the tube leaving it free of any dust and dirt contained in the tube. Once the tube has been cleaned you can take out the bin door and install the filter back in. Sadly the foam motor filter on the top hood cannot be cleaned or washed and has to be replaced.
If the filter tube however is completely stained and you dont have a free spare one to fit, the filter can actually be removed by removing the tie clips on the top and bottom of the holder. Wash the filter and dry in a tumble dryer - EBay in the UK sometimes sell filter squares which can be tied and locked to the cylindrical tube. Once the filter is dry you can then tie it up to the grid again and if the ties get lost, small computer wire ties are a suitable replacement.
Another feature of the Sebo X which has only just come to light recently with Sebo's user videos is use of the dry cleaning powder. Although Sebo don't actually tell you, by manually rubbing the powder into your carpet with just your fingers rather than raking it in on the top surface you'll get more out the first application of rubbing the powder in and letting it get a better chance of removing actual heavy stains. If you don't want to rub that powder in manually, remove the top hose by unlocking it where it meets the bag dirt channel on the left hand side of the machine at the top. (right hand obviously if you are facing the Sebo) then the Sebo X can be used as a rolling  brush to rub the powder in. After the 30 minutes minimum waiting time, lock the hose back into the X and vacuum up as normal.
This facility of removing the hose/thus cutting the suction is also very useful to rub in bicarbonate of soda into your carpets if you own pets. Bicarbonate of soda is an ideal natural odourizer which will maintain clean areas. Sebo's DuoP dry powder is ideal to do this as well for general stain protection if you like to keep your carpets clean.
The paper bags can also last a lot longer if the dirt your Sebo has collected remains half way at the top rather than naturally falling to the bottom of the bag.My X1 does this with new carpet fluff. Take the crevice tool and push the tool into the top opening of the bag to push the dirt GENTLY down - this will give you extra longevity on the bag used as well as not having to replace it so often.
There are ways to make your Sebo X1 cost effective!
on May 04, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Black and Decker 14.4 Dustbuster, how do I wash filter?
Here you go - this will take you to your instruction manual. It looks like you just wash it with soap & water and let it air dry.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90513719,chv9608%20etc.pdf
Jul 08, 2011 | Black & Decker Vacuums
User manual needed.
Black and Decker website offers product manuals. Also, various online vendors provided information I needed about DustBuster in product description, making it unecessary to purchase manual.
Sep 10, 2009 | Black & Decker V9660 DustBuster Handheld...
How do I open the dustbuster to clean out the end
There should be an area to press at the joint between the front section, and the motor section. The whole front cone comes off to empty the contents, and there is a filter - but no bag with these.
Hope this helps you.
Thanks for using Fixya
Dec 26, 2008 | Black & Decker V9650 DustBuster Handheld...
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Black & Decker V9650 DustBuster Handheld Wet/Dry Vacuum Logo
602 people viewed this question
Top Black & Decker Vacuums Experts
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
