Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman furnace ignition failure
I have a Coleman furnace and the green light is flashing once indicating an ignition failure. The furnace clicks but never comes on and then shuts completely down, hence the failure. Any suggestions on what I could do before I call a repairman
  • waterman_e Apr 06, 2009
    My Coleman Evcon furnace lights. When the blower comes on, the burner goes out. It goes through trial for ignition twice more then faults to 1 flashing light indicating an ignition failure. After resetting it goes through the same routine. I've replaced the high limit sensor and the flame rod. No change. I've bypassed the thermostat and both temp sensors with the same results. Any ideas?
    New Friend:
  • 92 Answers
The only thing you can do is turn it off for a couple minutes and try again sometimes you get it to lite off on retry otherwise call tech
Posted on Feb 05, 2009
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Gas furnace call for heat, Blower comes on immediately, no heat
Might be the pressure switch. If it gets blocked with dirt will not let furnace fire
Jan 25, 2013 | Tools & Hardware - Others
I have a gas furnace model # 2sg13b36090p-1a green light flashing 2 times slow
Hello, Maybe this will help you some.
http://home.howstuffworks.com/how-to-repair-gas-furnaces.htm
I hope it does, Mike
Oct 26, 2011 | Coleman Propane Forced Air Heater...
I have a coleman evcon furnace and it wont work it gives me a flash code of 1 what does it mean
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Dec 26, 2009 | Tools & Hardware - Others
Running out of LP??
Yes. The ignitor is trying to find fire and it can't. That's an ignition error. It should go away once you get fire to the sensors. You might have to hit a reset button, it all depends on the heater.
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Dec 04, 2008 | Heating & Cooling
Furnace not working. ok light flashing
The flashing light indicates that there is a problem. Turn off the power and then back on. Count the flashes and it will indicate the code to the problem. There will be a time pause between the flash codes. The most common problem is the failure of the hot surface igniter .
Dec 01, 2008 | Heating & Cooling
Ignition failure code on
Sounding like a flame proving device is failing to sense flame. Try to clean the device with some steel wool. It is located right next to the last burner looks like a thick wire. Take the steel wool and gently rub the carbon that has built up off. Should only take 4 or 5 strokes. Let me know it that did it. Ken
Nov 30, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
2,002 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
