Question about Ruud UAKA030 Air Conditioner
The heat relay is closing on call for heat but opening quicly
The unit is new and the heat has never run before. It is a heat pump with 5kw heat strip.
  • 1 more comment
  • tomholman70 Feb 04, 2009
    House temp is 65, it warmed up after the heat pump ran so that part is working correctly, thermostat set at 74, Heat pump is operational, 2nd stage heat (5kw heat strips) relay comes on for 1 second, then off for approx 10 seconds. The relay is fed through a board mounted on the fan blade housing. The relay states it is 24vac input/24vdc output. Unit is 240vac 1ph 60.
  • Ken Bledsoe May 11, 2010
    The thermostat has a selection switch cool off heat emg heat where is your switch set at?
    What is your thermostat set at is it heat or emergency heat?
    Problem Solver:
  • 15 Answers
Ok rheem and ruud is the only co that the hp is set to the b term on the stat for heat. is the stat wired corectly? is it a hp stat? and on a 2 1/2 ton hp you should have more than 5 kw. what kind of stat? the relay is correct because you have transformer that takes 208/230 down to 24 va. let me know.
Posted on Feb 04, 2009
Starter motor went out on 92 5.0 ho replaced it and new battery, now fuel pump does not work I get a 542 code checked fuel pump relay and inertia switch both good fuse good
  • Code 542 indicates one of the following conditions:
Engine Starts:
· Fuel Pump secondary circuit shorted to power
· Fuel pump relay contacts always closed
· Open in fuel pump monitor (FPM) circuit between ECU and connection to POWER TO PUMP circuit
· Heated Exhaust Gas Oxygen (HEGO) sensor shorted to power
· faulty ECU
Engine Does Not Start:
· Open inertia switch or inertia switch circuit
· Open in or between ECU and fuel pump (This includes open in fuel pump brushes/windings)
· faulty ground connection at fuel pump
The easiest way to check this circuit is to go to the fuel pump relay. If the relay clicks when the key is turned to the "RUN" position, then the inertia switch circuit is ok.
The Pink/Black wire starts from the fuel pump relay and goes two directions. One side goes back to the fuel pump. The other side is the fuel pump monitor circuit and goes to pin #8 at the ECU. This wire should only be hot for a second or two when the ignition is turned to the RUN position.
The fuel pump relay receives power on the Black/yellow wire. It comes from a fusible link at the power distribution center. This wire should be hot at all times.
If all the above is working as designed, them you probably have a bad fuel pump.
Feb 13, 2011 | 1992 Ford Thunderbird
I have an Intertherm electric furnace an sometimes it won't start but if I shut off the Tstat then turn it back on the furnace runs fine for awhile thought that it was T stat then thought that it was...
Electric strips have what's called a Sequencer also called a stack relay it's a relay that brings on the fan and strips at the same time on a call for heat. If you have more than 5kw you will have more than one Sequencer in fact you will have one for every 5kw.(only the first one will bring on the fan) It could be your high limit making your unit stop heating before it reaches the temp set on the T-stat. Check and see if your getting proper air flow across the electric strips your filter could be dirty. If not remove the cover from your T-stat and take the red and white wires off and twist them together this will bring on the heat then just watch the unit for about an hour if no problems then you have a bad T-stat. If the unit does cut off and the fan seems to be blowing fine you might have a bad high limit switch.
hope this helps........
Nov 18, 2010 | Heating & Cooling
How do i tell if the thernostat or water pump is broken?
Water Pump First. If the internal is not working the car will overheat very quickly. In 1 to 2 minutes of running. If the diapharm is broken the weep hole will be draining a large amount of coolant. The thermostat is a little tricky. Can be stuck open or closed. If stuck open it may take a long time to come up to normal operating temperature. If stuck closed it will also heat up very quickly. The car is new enough that should it heat up quicly it is most likely the thermo stat and not the water pump.
Jul 08, 2010 | 2001 Ford Escort ZX2
I have a HVAC unit made by Inter-City Products. I
In general, when more than one heat strip is present, one is used as primary heat, and the second one comes on if the primary does not prevent the temp from falling.
Another set up is, yes there can be a time delay in the system. it usually takes a few minutes for the second set to energize.
Since you did not state if this is a heat pump, i'm limited in my response at this time.
Hope this helps.
Dec 31, 2009 | Heating & Cooling
This is an early model livia 90 (~1994). Problem is no heating of water. Pump works but neither heating light or pump light comes on. I determined the power relay was not closing. Replaced it with new...
I would check the level probes on top of the boiler. There is a yellow wire going to the high level( left) and a green wire going to the low (right) probe. The probes get scaled and do not sense water. If there is no sensing of the right probe ( low water) it will not heat. They both need to be cleaned. There is a nut or a big nut that will allow for the removal. Clean both probes and it should go back to normal.
Dec 26, 2009 | Pasquini Livia 90 Espresso Machine
Compatability of a R22 air handler and a R410a heat pump
1. The units should match up without a problem.
2. You will need a 40 or 50 amp breaker for the A/H and 5 KW heat strip. You will probably need a 20 or 25 Amp for the condensing unit. I would check the FLA (full load amps) rating on both units, total them and install a breaker with no more than 20% more rating than the total. You can install a small box at the A/H with a breaker for the A/H and one for the condensing unit.
Nov 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Will conditioner run same amps cold weather
Usually connected to a 30 amp & 40 amp double breaker, if it is a heat pump. 30 for cool, 40 for heat, to turn on 1 or 2 heat strips. heat strips are rated 2 5kw each.
Nov 12, 2009 | Carrier Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Ruud UAKA030 Air Conditioner Logo
114 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
