Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
No ice are water
I have a frigidaire side by side model frs2ownf, am getting no water at cold water dispenser also not making no ice, have checked water inlet getting water also checked metal screen at inlet its not clogged don't know were to go from here.
    Problem Solver:
  • 11 Answers
MOST OFF THE WATER VALVES ARE DAUL WATER VALVES . CHECK THE OUT LET OFF THE WATER VALVES . IF YOU HAVE WATER IN AND POWER . AND NO WATER OUT YOU HAVE A BAD WATER VALVE
Posted on Feb 04, 2009
Ice maker not working on Frigidaire frs26kr4a
Good Morning Friend,
I understand that the ice maker is not working on your Frigidaire refrigerator, model# FRS26KR4A. First, make sure the wire signal arm is in the down or on position. Secondly, make sure your household water line is open. Thirdly, make sure your freezer is cold enough to keep items frozen. Fourthly, check the saddle valve, if there is one, to make sure it is not clogged or restricted by any foreign material. Lastly, Check to see if the water dispenser is dispensing water. If no water is being dispensed, the water filter could possibly be clogged and would need to be replaced. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire FRS26KR4A Side by Side...
Ice maker quit making ice how to find problem
I understand that your Frigidaire refrigerator, model# FRS26R4A, stopped making ice. Here are a couple of suggestions you may try, to get your ice maker to produce ice.
    1)Make sure that the wire signal arm, inside the bucket area, is in the down or ON position.
    2)Make sure your household water line valve is open and on.
    3)Make sure your freezer is cold enough.
    4)Make sure the water dispenser is dispensing water. If not, the ice & water filter cartridge is clogged or restricted by foreign material, and must be replaced.
    I hope this is helpful.
    -Best Regards-
    WP
May 22, 2014 | Frigidaire FRS26R4A Side by Side...
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
195 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
