Question about Sony Playstation 3 (PS3) Console
My ps3 doesn't show any of the Icons
My PS3 doesn't show anything except the background it doesn't show games,music,photos,internet,system settings,and all the other things don't show what should i do i called Sony and they had a recording that didn't have anything to do with my PS3?
  • Halo4life
    Halo4life Feb 04, 2009
    It didn't work
  • 48 Answers
Yea, i've called sony quite a few times myself and got no help.
You can use the 'new' feature they added. Turn on your PS3 and hold the power button till you hear two beeps, then release. Its a recovery menu you can use to try and fix it. If that doesnt work you may have to send it in for repairs, The menu only works on firmware 2.50 and up.
Posted on Feb 04, 2009
  • Randal Hinojosa
    Randal Hinojosa Feb 04, 2009
    If you did a system restore and it still didnt work, you'll have to send it in. Call Sony and do your best to navigate the menu, it takes some time to get what you need but if you can talk to a real person you'll be set. Its $150 to do, hence why mine is still glitchy.
At first my ps3 only showed the background screen without any icons, but after I switched it on and off severally, it no longer showed anything on the screen i.e the screen remains blank
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Sep 08, 2011 | Video Game Consoles & Games
My PS3 has been broken for a very long period of time. About 6-9 months now, I've lost track. Every time I turn it on my PS3, it starts with the wavy animation and the colored background, and then the...
Ok, please try the following steps :
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep a total of 3 times and turn off again. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, then 5 seconds later it will beep again and then it will beep twice quickly. Let go of the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this then continue to the next step
Step 5. The PS3 will load with a menu with 6 options, choose number 5 "Restore PS3 System" and follow the on screen prompts.
Using this method should sort your PS3 out for you.
Hope this helps
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 turns on and shows the wavy background for the home menu screen but no menu icons show up. Nothing on the controller changes anything and icons never come up. The wavy colored background is there...
This problem is because your PS3 software has become corrupt. The following steps will cure the problem but you will lose saved games and all other data. Your trophies will not be affected as these are stored by the Playstation Network.
Step 1. Turn your PS3 onto standby (Red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, beep 5 seconds later then beep once more 5 seconds later and then turn back to standby. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and then beep twice quickly. Let go of the power button as soon as you hear these two beeps.
Step 4. The PS3 will start up asking you to plug in a controller with a USB cable and press the PS button. Do this and it will boot into the recovery menu.
Step 5. Choose option 5 (Restore PS3 system). This will re-install the PS3 software and restart the console.
Step 6. When the PS3 restarts you will be asked to enter the time and date and other information. When the setup is complete your PS3 will boot into the home menu normally.
Hope this helps
Aug 11, 2010 | Sony Playstation 3 (PS3) Console
My PS3 dos not allow my controllers to connect and also does not show anything but the background
did u try pressing the middle button on both of them if u did that then u need to charge the controllers
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Ps3 no icons only background wave
try holding down the power button for about 6 seconds to reset it.
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3 screen
PS3 is The amazing device by sony but it has some common problems like Screen/video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Wont run correctly
It sounds like a system file error due to trying to hack background, so check the CSS template and the theme.css to see if they are present in the theme folder. You will have to take hdd out and run on a pc to do this, you can find how to remove hdd by looking on search engine. If you get a 403 error, that means you are not allowed access. You will have to delete and reload the file from a known working ps3 hdd.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
125 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
