Question about Gateway 7330GZ Notebook
Gateway 7330GZ Not Booting Properly
Good Evening,
The above Laptop just started going from the Gateway screen to the screen that say start windows normally to the Windows XP screen & keeps repeating.
Can any shed some light on what is causing this please?
    President:
  • 2,992 Answers
Unfortunately, I've seen this caused by both hardware problems (something on the system board) as well as software corruption in Windows.
Try pressing the F8 key when you see the Gateway logo screen (press it three or four times). This should, if Windows is healthy enough, get you to a startup menu screen. Pick the option of starting the last known good configuration and see if that lets Windows start.
You can also try using the Windows Recovery Console if you have access to a Windows XP system disc. (Your computer may have come with one, or maybe you can borrow one.) Boot from the CD. After Windows goes through its file copying and setup stuff, you will see an option of pressing 'R' to run the recovery console. Start the recovery console and enter the CHKDSK command. This may take a while to run, but it often corrects the problems that are keeping Windows from starting. After the command is done, enter EXIT to leave the recovery console and restart Windows.
You might also consider backing up (copying) the contents of your hard drive (My Documents folder and other program data) onto CD or DVD, and then reinstall the original factory software. This can be done by removing the drive from your laptop and connecting it to another computer with the appropriate adapter cable. A computer service shop could do this for you if you don't have the necessary adapter for a laptop drive.
A service shop could also diagnose the computer if it looks like a hardware problem is the cause, and give an estimate for the repair.
Posted on Feb 04, 2009
  • 44 Answers
Probably a virus, or your windows folder got corrupted. Try to use Knoppix (A linux distrobution that boots from a CD) to get all your data onto a pen drive or external hard drive. Download the Knoppix ISO at Knoppix.com and burn it onto a CD or DVD using MagicISO (magiciso.com). Insert the CD, and you should see the boot screen. Open the file manager, and copy all the files you want to keep from your hard drive to a pen drive or external hard drive. Then, reinstall Windows using a recovery CD (one might have come with your computer). Copy the files back, and PRESTO!
  • 201 Answers
Try taking out the ram then boot
if not reinstall xp
if still reboots check fans for overheating
Posted on Jul 19, 2009
When i try to start up my laptop, i get a black screen that says "NTLDR" is missing" and "press Ctrl+Alt+Del to restart" when I restart it, the same screen just reappears. I've also tried pressing F11 to...
The file can be copied from different computer using the same operating system and same version..It can only be done if you can hook up your hardisk from that computer and make it as slave...go to search file and search for the NTLDR file and its directory. copy the file and save it to the same directory of your hardisk slave. If file copying is successful, disconnect your hardisk from that computer and connect it to your laptop, then try to boot.
If that did not work, you can repair your missing file by running your windows installer. Make your cd rom as first booting device and run the setup of windows, when prompted, press F8.. follow some instructions. After searching previous windows system press R key to repair the system.. The set up will restart your unit once its complete.
i hope i help you with this...
much appreciated if you rate this solution..thnaks.
May 29, 2010 | Gateway 7330GZ Notebook
Blank screen
Try plugging the laptop into an external monitor to make sure the laptop is booting up properly. If it is unplug the monitor from the laptop; or if you know the laptop boots up fine and you get the windows audio when it boots and the initial starting beeps then forget the monitor. Shine a torch or light source on the screen and if you see a faint picture then the inverter on the screen has developed a fault.
jon
Nov 04, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
Gateway 7330gz will only run few seconds then turn off
Remove the battery and run off of the A/C power adapter without the battery installed.
If it works, the battery is just discharged too much. After Windows settles, insert the battery and let it charge.
Sep 09, 2009 | Gateway 7330GZ Notebook
Can someone provide me online recovery disk of gateway 7330gz
You must set the boot sequence of the system to cd/dvd rom first which will enable the system to look for booting files in the disc in the first instance.
In your case your system is booting direct from hard disk. Boot sequence can be changed ib the bios setup of your system.
In some laptop models the restore files can be accessed by pressing function keys while system starting.
Mar 12, 2009 | Gateway 7330GZ Notebook
Notebook Gateway 7330GZ won't boot
Hm...That sounds like either the motherboard is dying/dead or a device is (such as the hard drive). I would suggest removing one piece at a time and see if you can get past that screen. The most annoying would be if it is the DVD drive since it's probably the most difficult device to remove from the laptop. (If memory serves it involves removing a certain screw from the bottom and then getting under the keyboard so you can push it out).
Do you have a second stick of RAM installed? Mine died a while ago and caused real heck with my 7330GZ.
Nov 16, 2008 | Gateway 7330GZ Notebook
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
Sep 30, 2008 | Gateway 7330GZ Notebook
Gateway laptop 7330gz
Some possible causes
--Some laptops have a function key that can turn off the screen when you have an external monitor running. Check your documentation to find out.
--The lamp burnt out.
--Cover switch (when you close laptop) is stuck/jammed/loose.
Sep 15, 2008 | Gateway 7330GZ Notebook
Gateway laptop
gateways have the recovery built on the hard drive. just hit f11 on starting up the laptop( before the gateway screen) and it will reformat it back to out of bx state.
May 05, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ laptop. Good battery, good Ac Cable will not turn on?
The system board on the laptop needs replacement.
Hope this helps :)
Nov 25, 2007 | Gateway 7330GZ Notebook
Gateway 7330GZ will not follow through at start up
At startup, hold down F8 key. select safe mode start. allow windows to guide you from there. if no-go, then repeat but choose dos prompt only, then insert a win 98 startup disk and run scan-disk on your drive. if no-go, in worst case, try to delete the pagefile.sys file from dos prompt (you may need to change file attributes from read-only and hidden and system to toggled-opposite-read, not hidden, not system). and repeat above steps
May 27, 2007 | Gateway 7330GZ (890552601318) PC Notebook
Gateway 7330GZ Notebook Logo
156 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
