Question about Sony Cyber-Shot DSC-U30 Digital Camera
Seems like batteries don't work, but . . .
Camera quit working. I figured the Ni-Mh batteries quit. I bought new batteries and the camera still didn't work. I hit the reset button and the camera was back, but only for a little while. I shot about thirty-forty photos and now the battery light keeps flashing and it won't work at all even with a fresh charge. If I hit the reset button now, the problem goes away momentarily, but comes right back after one or two shots. I've tried three different brands of rechargeable batteries and the problem remains.
  • Joseph Long Dec 03, 2012
    There is definitely something that drains the batteries in this camera at a higher rate than when it was new. I bought some 1200 aH batteries and that has helped, but it's also something internal. I find that turning the unit on when simultaneously pressing the on button and the menu and the execute button does a soft reset and the battery indicator level will read full whereas just turning it on makes it read as barely full, which causes the camera to think there is no juice in the batteries.
  • 3 Answers
I think the problem was either dirty battery contacts or a broken connection somewhere with the battery terminals. I'd cleaned the contacts a number of times with a pencil eraser before, but nothing worked. This time, I just did it again and paid careful attention that both contacts on the battery door were protruding properly--could be that one of the contacts got pushed back such that it wasn't making proper battery contact. All I know is that it's working now, perfectly, after sitting for a couple of years on the shelf. I really like this camera.
Posted on Feb 04, 2009
You can use that battery. IT wont last as long as the alk or the Nimh
Aug 01, 2014 | Samsung ES30 Digital Camera
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
The camera seems to drain the batteries very quickly when not in use, example I put in new batteries and 4 days later they showed half full on the screen. They were the AA Ni-MH rechargeable batteries.
Be sure that your Ni-MH batteries have a high enough capacity to hold their charge for extended periods. The cheaper batteries are just that. If you have not tried this, get some new Energizer 2300 milli amp hour batteries. These should perform much better for you. If that does not solve the problem or you don't need to get new batteries, check to be sure there is not a continual contact that works like keeping the camera on all the time. I have seen this on another fix suggestion. Hope this helps. Keep looking for solutions posted on the web.
Jun 25, 2010 | Kodak EasyShare CX7300 Digital Camera
I try to turn my camera on and all it dose is click
Don't use standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Oct 04, 2009 | Fuji FinePix A850 Digital Camera
Please replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
Aug 18, 2009 | Fuji FinePix A850 Digital Camera
Camera will not work after Ni-MH and Ni-Cd batteries used
Its not good for the batteries to combine different types but it shouldn't have affected the camera as the voltage they produce is the same. Try a couple of Eveready AA lithium batteries.
Feb 10, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Hp 435 digital camera battery
The NI-MH batteries are the Best for use with Digital cameras....U need to Charge the New Battery for 12 Hours The First time and then 2-3 hours for every other time you charge ... try and check please
Oct 14, 2008 | HP Photosmart 435 Digital Camera
Camera won't stay on
Are you using alkaline or 2500ma batteries or better
Sep 30, 2007 | Samsung Digimax S730 Digital Camera
Can't use chargeable batteries
If your camera doesn't work with NiMH, then it's most likely that you have either one or more bad atteries, or your camera is defective. p. 6 from the user guide: "..Ni-MH batteries left unused in storage for long periods can become ?deactivated?. Also,repeatedly charging Ni-MH batteries that are only partially discharged can cause them to suffer from the ?memory effect?. Ni-MH batteries that are ?deactivated? or affected by ?memory? suffer from the problem of only providing power for a short time after being charged. To prevent this problem, discharge and recharge them several times using the camera?s ?Discharging rechargeable batteries? function. By repeating this cycle several times, the temporary reduction in performance caused by ?memory? or ?deactivation? can be remedied and the batteries can be restored to their original performance levels. ..." Sorry i cant help you more..
Dec 23, 2005 | Fuji FinePix A310 Digital Camera
Sony Cyber-Shot DSC-U30 Digital Camera Logo
96 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
