Question about Whirlpool Duet GHW9150P Front Load Washer
Washer is flashing f and dl and isnt draining correct.
Flashing f and also dl what is that it also isnt draining right
  • Anonymous Feb 05, 2009
    I have the same problem, plus my washer smells like a sewer after i do a load.
  • Edgar Braceros Feb 06, 2009
    whirlpool duet ht-ghw9400plo washer is flashing f,l and stops in the middle of washing...sometimes it doesn't start at all... please help!!!
    Scholar:
  • 99 Answers
This is joyce
First of all unplug unit from wall to reset. leave unpluged for 1 min. then replug back
check to see if you lines are not crimped where your water goes out of machine. if this dont work to get your codes go to web site whirlpool.com and type in your model # and download your documents and find your codes and then you can go from their, I have the same thing you have and believe me I have had my share of problems with mine, but nothing like you are having, thank goodness I had exstended warranty for 5 years, it is exspensive to work on these units. dont try to work on them yourself they are all high tech. if you need help finding someone to work on your unit just email me.
thanks
joyce
Posted on Feb 07, 2009
Washes but lights come on and flash and beeb and will not rinse
sounds like it isnt draining, can you tell me which lights are on reading from right to left e.g. 1,3,6
Sep 29, 2014 | Fisher and Paykel GWL11 Top Load Washer
Washer doesnt drain
Suds Detection
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify:
Excessive detergent usage.
Basket cannot engage during drain step.
Mechanical friction on drive mechanism, not allowing basket to engage.
Nov 04, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing machine is just washing draining but not spinning
1) door inlocked when washer is running, read your troubleshooting section and proceed according . or call customer service and get assistance via online chat.
God bless you
Jun 21, 2012 | Samsung Washing Machines
HE4t 45981 Washer dl f and F11
The DL F error is saying that the door lock mechanism is faulty and will need to be replaced.
Mar 05, 2012 | Washing Machines
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
My whirpool Cabrio says dl when i start the machine what does it mean? And how do i fix it?
Hi
Thanks for using FixYa. Error Ld or dl means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore oasis is showing the dl code all of a sudden- and there is nothing blocking the washer...help! i was using it last night and all was fine, and this morning the code started flashing.
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
When started, pump functions to drain, but, does not stop and start to fill--after a period of this, the door stays locked with all lights flashing. Essentially, the machine does not cycle correctly.
ok, sounds like you should be seeing an error code flashing in the display with the lights. this will be an F followed by a number. or letter abbrev. like dL
With the pump starting with a new cycle started and draining but you get this light sequence (error) I believe the problem would be that it is seeing water in the tub and not seeing it leave, like a pressure sw problem.
Apr 26, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
