Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Clean light will not go out
Kitchen aide dishwasher clean light will not go out. Dishwasher cannot be stated. Clean light blinks. When you press the cancel light dishwasher starts for about 20 seconds.
  • 188 Answers
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 03, 2009
I had this problem and diagnosed it back to the heater element. I replaced the heater element and reset the unit like is mentioned and had success!
Posted on Mar 27, 2009
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
I have a Kitchen Aid KUDKO1ILBS1 which is constantly blinking clean. I have replaced the circuit board once because the capacitors were bulging blown out. After replacing the board the dishwasher has a...
Hi
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Thanks Daniel
Aug 13, 2010 | KitchenAid KUDK01TK - Multiple Color...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
Cannot get D/W to wash...can't cancel out blinking lites
might be the circiut board had similar problem with my old kitchen aid unit
May 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
KUDI01TJWH0 kitchen aid....the clean light is blinking and wont do anything else....how do we reset or do we just need to take it in for repair?????
To invoke the diagnostic cycle, perform the following key presses in less than 6 seconds while in standby.
Heated Dry -> Normal -> Heated Dry -> Normal
Invoking the diagnostic cycle clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle. (quoted from service diagnostic cycle notes in troubleshooting guide)
Apr 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Blinking "rinse only" & "cancel drain" indicator lights
have you unpluged for 5-10mins? check manual for fault codes..genrally in rear. Sorta sounds like a drain problem...maybe...very common.
Jan 03, 2008 | KitchenAid KUDR01TJ Dishwasher
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
446 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
