Question about SanDisk Sansa e200 MP3 Player
Stuck on hold!
I accidentally pressed the hold button and now it just wont turn back on. i tried everything and it won't work
  • 6 Answers
I removed the back (didn't have #0 phillips, so used 1/16 flat head), removed the battery, reinserted the battery and it solved the problem. Tip: can buy sets of small screw-drivers at a dollar store, Odd Lots, etc for about $1.
Posted on Mar 02, 2009
    Problem Solver:
  • 11 Answers
Does it not working mean that you get a "key Locked, system shutdown" message, The thumbwheel glows but nothing else happen, nothing happens, or something else? If it is the first case and sliding the control does not work, the exterior slide has probably disconnected from the switch on the board. To fix it you will need to remove the 4 screws in the back to take it off (just slide your nails inbetween the metal back and the piece between the 2 covers and pry). Same thing for the front cover ( the black, plastic one) the screws are underneath the metal cover- one screw at each corner. I use a #0 phillips screwdriver for all 8 screws. the slide and the switch should now be visible, just slide the slide onto the switch - if not, something came apart and you need someone who knows what they're doing to fix it. if the thumbwheel glows but the screen does nothing you probably broke the screen. If nothing happens, It's probably scrap time for it.
Posted on Feb 14, 2009
I have the trio g5 10 and it gets stuck on the loading screen that says android and wont just wont turn off ....ive tried everything
Hi try holding down power button for approx 30 second's if this doesn't work hold Down power button & volume button at the same time & hope it reboots .cheers
Nov 04, 2017 | Tablets & eReaders
Stuck sleep mode
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
Aug 19, 2017 | Toshiba Computers & Internet
My WP-350 is stuck and wont turn on/off
I'm having the same problem with my Creative WP-350 Wireless headphone; the blue light stays lit. I've tried charging the device fully and pressing the + (volume increase) and the multi function buttons with no success. There has to be someone out here that can provide the solution. I wrote to the Creative tech folks too, awaiting for a reply
Jul 07, 2013 | Creative WP-350 Headset
How can I fix this???
See if you can leave ideal to adjust its performance and try turning it off after about 30 mins to 40 mins
Jun 12, 2013 | Audio Players & Recorders
My usb overheated and now wont light up and let me see my files
This is WORKED FOR ME!--->I turned off my computer than unplugged cable and took out battery, held down power button for 1-2mins and than put everything back in (battery and charger) and tried to start it...the screen was still black. I than turned it off again, than pressed ESC, while holding down ESC I pressed and held power button until it briefly turned on and back off. Than I let go of both the buttons and pressed power back on and VOILA the screen came back on. Make sure your charger isn't loose, and than you're aren't surging too much power through the outlets-sometimes these can make the screen black too.
Hope this helps others out there, I have an old Toshiba Satellite running on Windows Vista
Jul 27, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I just had my brakes changed on my 2006 passat. Now the electronic parking break sensor won't stop beeping but everything works. How can I get the fault to go away so It will stop beeping
also if u take battery off for 10 mins, hook battery back up again, turn car on, hold in break paddle for 35 seconds, then still holding in break paddle hold in handbrake button for 10 seconds, release all and start car up, press break button a few times, turn car off again take out key, lock and open car then press break button again and now all should b back to normal
Mar 27, 2012 | 2006 Volkswagen Passat
Topside control issues
Topside control is in "Locked" mode.
If you accidentally locked your control
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
or
One of the buttons might be stuck in the down position
If these do not help let us know your control make and model & we'll see what we can do to find out more for you.
Dec 31, 2011 | Dream Maker Spas Pool & Spa
GPS INSTRUCTIONS
this may sound silly but your reset button may be stuck on on.
try resseting everything and updating the device.
Jul 01, 2009 | GPS
Printer cartridge alignment
Another solution...we were having the same issue, but we found out that our black cartrige was out of ink...and when we replaced the cartrige with a new one, the "align cartriges" message when away once we pushed it one final time...we are in good shape now...yes, we are idiots.
Oct 05, 2006 | HP PSC 2175 All-In-One InkJet Printer
SanDisk Sansa e200 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
