Question about Kenmore 73932 Gas Dryer
Kenmore dryer buzzes but does not run
My Kenmore series 90 model number 76902690 will not run. When attempting to run a cycle the dryer will buzz only, like at the end of a cycle, but never actually turns on.
  • mikes1212 Feb 04, 2009
    MrMark, Thank you for your reply.  The dryer does not run at all.  When pushing the start button all I get is a "end of cycle buzzer.  The buzzer sounds for as long as you hold the start button in.  I have been able to manually rotate the drum.  I have not checked the hose to see if it is clogged.
  • bjbaber Apr 28, 2009
    I had just dried a load and it finished the cycle (or I thought) and when I went to put it on for a few more minutes all it would do is buzz!
    I have a Kenmore 90 Series electric dryer
  • 1,214 Answers
You could have any one of several problems with that gas dryer -
Turn dryer on.
Go out to where dryer duct exits house.
Feel the amount and strength of air blast coming from vent.
Air blast should be strong and cover the full face of the vent.
If not, check that dryer hose is not crushed/collapsed behind dryer as it is pushed back into position.
Clear any restrictions in the vent pipe.
Clean lint screen.
Check that there is no restriction where air is pumped into or discharges from the dryer drum on the inside.
If you are able to, check to see if you can see the pilot ignitor lighting.
Reply back your findings for further instruction or information.
Posted on Feb 04, 2009
  • Mark Egan Feb 04, 2009
    Sounds like the door switch has failed.
    Do you know how to troubleshoot electrical circuits? I can guide you. Or, you can just go get a new switch and install it.
    I'm pretty confident we've hit the problem. Reply back and I can give you some ideas of what to do.
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ... > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ... > Manage My Life > Questions
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ... > Manage My Life > Questions
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
We have a 80 series elec. dryer, today when the end of cycle buzzer sounded, when door was closed again...buzzer continues to buzz. I can't find a part number, if the end of cycle buzzer needs replacing. ...
Push the timer to a definate off position. Close the door. If it buzzes then more than likely you are getting power from the timer which could mean short in the timer. If you have the model # the parts places can easily find your parts.
Dec 28, 2010 | Kenmore 800 6983 Electric Dryer
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 | Dryers
Kenmore dryer 60 series won't turn on
Feb 28, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Kenmore dryer runs then shuts off
The parts store should have never sold you the motor. They rarely if ever fail on a dryer. It sounds like a limit switch or sensor wire was damaged by the burning. Check out the wiring and if you feel comfortable jumper out one switch at a time to see which one is not working. Do only one at a time. Photograph everything before you take anything apart.
Mar 04, 2017 | Kenmore Dryers
Kenmore 73932 Gas Dryer Logo
686 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
