Question about Sanyo DS25390 TV
DVD player connection
Where is the DVD player connection on this model of tv? Please help! Cindy
    Problem Solver:
  • 8 Answers
This s gizmofreak
the solution to the above problem please reffer the followin url
http://portablemedia.manualsonline.com/ex/device/headline/d/portable_tv/type/manual_request
please do me the rating
Posted on Feb 04, 2009
Where to hook up white/yellow input wires from receiver to panasonic TC-P50S2. HAVE audio no video feed on tv
Usually DVD players have either composite or component video out (unless you are using HDMI connections). That means you need three or five RCA plugs connected between the devices.
The usual pattern when using a receiver would be to connect the Red/White RCA cables between the receiver and the DVD player audio out. Then connect the Yellow (composite) or Red, Green, and Blue (Pb, Pr, Y component) video cables between the TV and the DVD player. Make sure the connections match at each end; with component video, it can be easy to mix them up. Not all receivers have composite or component video outputs available to the TV. The Composite video will go to the yellow connector at Video In 1 on the TV. The Component video would go to Component In 1 or 2.
Since you don't mention the model of the receiver or how that is connected to the TV, I can't be sure why you have no video. If you have an HDMI connection between the TV and the receiver, the receiver won't convert the signal from composite/component video to HDMI.
The alternative method of connecting everything would be to connect the DVD player to the TV (both the audio and video), then use the optical digital audio connection from the TV to the receiver or to a digital to analog audio converter and then to the receiver.
Please add a comment with the rest of your A/V equipment for a more solution.
I hope this helps.
Aug 01, 2016 | Panasonic Televison & Video
I am trying to connect a sony dvd player by rca cables to my tv and it only plays in black and white.do I need specific cables
Wallie, If possible save your self some aggravation and get a HDMI cable, if you have that option..
press the helpful button and follow me on fixya for more tips and info.
Feb 10, 2016 | Sony Televison & Video
Dvd to tv I have audio with no visual
How do you have the DVD player connected to the TV? My dvd player has component video out; when I accidently swapped the green and blue RCA inputs, I had no video but the audio was fine.
Thus, check your cables and make sure that they are all connected to the matching input and output. You may want to try a different cable, in case one of the wires is damaged.
I hope this helps.
(You can also try connecting a different device to the TV or the DVD player to another TV to check if the problem is with the TV's inputs or the DVD player's outputs.)
Nov 23, 2012 | Sharp LC46SB54U 46 in. LCD TV
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
I do not have my manuel. I am trying to watch a dvd but can not seem to find the channel on my dynex to play
Which model DVD player do you have? How are you connected to the TV and what model Dynex is it?
On some older TVs, you can select AV (composite) video in by going down in the channel list past channel 2. Other TVs have several inputs (composite, component or HDMI). For those, you need to press an input or source button and advance to the input on the TV that you have connected to the player to watch the DVD. Some TVs have this button on the TV; all have it on the remote. If you do not have the original remote, you will need one with a button that can match the feature. It may take searching through all of the Dynex codes for the universal remote to enable the feature (other codes may do the basic TV functions).
There are a few TVs where you can change the source from the On-screen Menu system but those are less common.
I hope this helps.
(If you want specific advice, please provide the make and model of the DVD player and the model of the TV. I may have the manuals in my stack.)
Apr 10, 2011 | Televison & Video
I cannot hook my dvd and dish network up to the tv at the same time. How can I do this? Samsung series 4+450
I assume that you are dealing with a TV with only one input of a given type. Depending on which input you are sharing, get an appropriate switch (Composite video, component video or HDMI). HDMI switches can be manual or have a remote. For a few HDMI models: http://us.startech.com/product-list/switchers . For some Component video options: http://www.svideo.com/com3.html .
How are you connecting the devices to the TV? Which inputs do you have available on the front, back, or side of the TV?
I hope this helps.
(The limit here is the TV.)
Jan 13, 2011 | Apex Digital AD-1100 DVD Player
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Need owners manual for proper connections to tv w/direct connections I hsve a sony dvp ns300 cd/dvd player
The connection you use will depend on the TV. For the best picture, connect component video cables (not included) from the DVD player's output (to the right of the other jacks on the back of the unit) to the component video in of the TV. Then connect the Right and Left audio from output 1 to the appropriate audio input of the TV. (These may vary depending on the TV and other devices connected to the TV. They might be audio 1 or part of a group with the component video inputs.)
Otherwise you can use an S-video cable connection and the separate audio cable or the composite video cable (which has 1 yellow RCA plug for video and 2 others (red and white) for audio). Connect these from the output of the player to the matching input ports of the TV.
For TVs with only RF in, you need a composite video to RF modulator (converter). See a store like Radio Shack for this.
The manual is available from Sony: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPNS300 . Pictures of the connections start at page 15 and more detail is provided from page 17 through 23. See the manual for details if you have a home theater system or other external speaker option.
I hope this helps.
Dec 08, 2010 | Sony DVP-NS300 DVD Player
Sanyo tv ds27820
maybe your connection is wrong,look at back of your dvd player and find the yellow socket and that's a video the red and white is for the sound. using the color coding connect your dvd to tv, be sure that the terminal that you use is audio/video input
Oct 08, 2008 | Sanyo DS27820 27" TV
Televison & Video Logo
89 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
