Question about D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater
Setting up my DWLG710 EXTENDER
I have a belking router 192.168.2.1 address. how to I get my DWLG 710 192.168.0.30 to respond?
  • CABLEGUY9177 Feb 04, 2009
    i did what you said Harry. got great signal upstairs with the extender. It started to use 169.254.107.56 it went back in forth between 192.168.2.1.?????>?
  • 63 Answers
You need to give IP add manually to any of ur PC as 192.168.0.31 and than open DWLG setup page on the browser by typing 192.168.0.30. It will bring the setuup page of Extender.. on this page change the IP add from 192.168.0.30 to 192.168.2.50.. it will restart ur extender and make it working in same network... roll back the changes u made to ur PC to connect..
Posted on Feb 04, 2009
I have many times tried to set up my DWL-G730AP Wireless Router with no success. I have typed the url http://192.168.0.30, but keep getting a list of web pages so I have to use my system without security...
This is the correct address to log on to your router. 192.168.0.30 so i dont know why you are having problems.
Try to reset your router (press and hold the reset button for 30 seconds) and then follow the guide i found here, give the page a minute to load, it is fully illustrated with pictures, so is a little slow to load up
http://www.scribd.com/doc/14641796/DLink-DWLG730AP-Quick-Start-Guide
Aug 13, 2010 | D-Link AirPlus G Wireless Range Extender...
Different router and extender signals
you are seeing your neighbours wireless as well. hook up to the one that is your router/provider
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
Connection of dlink range extender
I have this unit. Make sure that the network you are repeating is set to stay on a certain channel. The router I was repeating was set to dynamic channels so that it changed based on what channel had less interference. The dlink repeater does not like that and needs the channel to stay the same.
Apr 28, 2009 | D-Link AirPlus G Wireless Range Extender...
Range Extender
Both router and range extender must be setup with the same SSID, encryption key and same FIXED channel assignment.
Jan 22, 2009 | D-Link AirPlus G Wireless Range Extender...
DLink Wireless Extender
  1. move the router,
    the router can be anywhere, as long as it is connected to the modem
  2. reorient the antenna,
    its surprising just how much difference changing the antenna direction has.
  3. ensure the router is broadcasting at 100% power in the router settings page
might not solve the problem, but have worked in the past
Jun 23, 2008 | D-Link AirPlus G Wireless Range Extender...
D-link range extender
with d-link range extender Im trying to cofiger it with conect it direct to the computure but the result not find server
Mar 16, 2008 | D-Link AirPlus G Wireless Range Extender...
Comm problem between range extender and BT home hub
make sure the SSID, channel & wireless key on router & all extenders are the same, also the default gateway on the extender has to be the IP address of the router.
Nov 27, 2007 | D-Link AirPlus G Wireless Range Extender...
D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater Logo
825 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
