Question about Brother MFC 5100c InkJet Printer
Printer/copier does not work.
Display reads-machine error code 41,unplug machine and call brother.
  • 561 Answers
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usually just after warranty has expired!
Posted on Jan 10, 2010
What is error 41
error 41 is a critical error with the print head of your machine, you can try unplugging it for a while then plugging it back in but if that doesn't work it will probably need a new head. If the power cycle doesn't work I would suggest buying a new machine
Oct 04, 2010 | Brother IntelliFAX 1800C All-In-One...
Dear Sir I have a technical error 41 and i dont know what to do.
When did the problem start on the printer
Thanks
proton
Aug 06, 2008 | Brother Office Equipment & Supplies
Error 41. Unplug machine and call Brother
Hi there
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
Mar 04, 2009 | Brother MFC 3100C All-In-One InkJet...
Brother MFC 3100 Printer/fax
This is the only reference I could find on error 41: How can I clear the message Machine Error 41 from the display? (ME41)
Machine Error 41 indicates a mechanical malfunction of the Brother
machine. Unplug the unit from the power source and then plug it back
in.
If the error message continues to be displayed on the LCD, please call
Brother Customer Service at 1-800-284-4329 for assistance. The Customer
Service center is open Monday through Friday, from 9:00AM to 7:00PM,
excluding holidays If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Office Equipment & Supplies
My Brother MFC-3420C has an error code of "Machine error 41"
While there are many ways to prevent Brother printer error code "41
May 07, 2008 | Office Equipment & Supplies
Brother Machine Code 41
error 41: ph is defective and needs replacement.
Mar 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Error 41 in brother 210c
Error 41 means that the printhead is defectiv! You need a new printhead. Sorry, it cant be fixed anymore.
Oct 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Mfc4420c
Uninstall all of the software, if the software is still installed. Unplug the printer, reinstall the software,plug the printer in,reboot the computer. If you still get the same error, remove the usb cable and plug it back in. This happens either because the software is not fully installed correctly, so the com0puter can't read the all in one. OR the USB cable is messed up which inturn the PC can't read the printer fully. If after installing the software and checking the cable you still got the issue, all in one is having communication issues. You will most likely have to call brother for that. Also make sure to try to printer on another computer if you can. If it works on another computer, its software. If it doesn't its not software its the cable or the printer messed up. Also at times I noticed brother printers need reset on the interface of the printer. You should be able to call brother to get the maintenace code to reset the printer.
Jul 18, 2007 | Brother MFC 4420C All-In-One InkJet...
Error 41 on Brother MFC-3420C. I have tried unplugging and restarting. There aren't any paper jams or visible problems. There is dial tone to machine but fax will only ring when called, no start tone...
Hi,have the same problem since yesterday. Look on fixyourownprinter.com. """You can fix the ERROR 41. Go to www.bopparts.com and look up part# LK0935001. They sell it for $39.99 and it is very simple to install""".Good luck.
Apr 13, 2007 | Brother MFC 3420C All-In-One InkJet...
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Brother MFC 5100c InkJet Printer Logo
108 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
