Question about Toshiba SD-3990 DVD Player
DVD player won't play DVD, says "load"
I have a Toshiba SD3990 player. When I try to play a DVD, the player just reads "load". I have tried several DVDs that have been previously played on this machine and the same statement appears. What can I do to fix this?
  • 4,234 Answers
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Posted on Feb 04, 2009
  • ektakrome Aug 27, 2010
    I thought this was my problem too. But after messing around with it for a while. I realized that it had a DVD stuck inside it, well it finally came out with another DVD under it. And Now is working perfectly again. YEAH!
SOURCE:
How do I restore Toshiba DVD player SD3990 back to original without password? Forgot password.
If you forget your 4-digit code
If you forget your password, to clear the current pass-
word, follow the procedure below.
1 Press SETUP to display the setup menu.
2 Use the Number buttons to enter the 6-digit number
"210499".
The 4-digit password is cleared. "P CLr" appears on the
display for a moment.
3 Enter a new code as shown above to the left (Rating)
Dec 05, 2014 | Toshiba SD-3990 DVD Player
Toshiba SD 3950SU DVD Player won't read discs
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
May 30, 2012 | Toshiba SD-3950 DVD Player
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
I am going out of my mind trying to dub VHS to DVD on my new Toshiba DVR620. Please help!
I have a Toshiba HDD&DVD vcr RD-XV48DTKB will not accept disc or play any disc have tried several makes even new ones it just loads then says error cannot play eject will not play or record HELP
Jan 22, 2011 | Toshiba DVR620 DVD Recorder/VCR
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
Hi -- my toshiba SD3990 model DVD player won't
Your DVD player is fu.k.d up.  These things are made so cheap now a days that it is more trouble to try to fix the thing, than going out and buying a new one.  You can try running a disc head cleaning kit through it first to see if that helps.
Nov 23, 2009 | Televison & Video
Concept car overhead dvd model p1020 wont play dvd
Laser is off track, weak, or just bad. any way it goes it needs to go to the repair shop.
Aug 21, 2009 | Concept P1020 Car DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Toshiba SD-3990 DVD Player Logo
1,287 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
