Question about Toshiba G15-AV501 Qosmio Notebook
Whats the trick to get into the BIOS of a Qosmio G15R-AV501?
Qosmio G15R-AV501, XP MCE. Real long boot cycle where there is no apparent activity. Probably doing tests, but the splash screen never gives me an indication to hit F8 or delete or whatever to get into the BIOS.
  • Toshiba Master
  • 2,404 Answers
Try F2 as soon as you turn on the laptop or even try F12 cause that would get you to the boot menu and you can choose enter setup from that point.
Posted on Feb 04, 2009
    Problem Solver:
  • 7 Answers
Hello, I use the ESC key and it takes me to the BIOS on my G15R. I am missing one driver from my laptop and can't figure out which one it is? I have all the rest if anyone needs them. I think the one I'm missing is something to do with media and sound.
Try the ESC key bud.
Cheers
Posted on Oct 21, 2009
  • 679 Answers
Look at the bottom of the screen when it boots up, it will give you the commands down there, normally it's hohl the delete key on a restart., Taping F8 will bring you into safe mode. delete -bios, f 8-safe mode
I was given a qosmio G15-AV501, but it appears to be overheating about 10 minutes of operation. It will run for a little while, then just shuts down. Between 5 and 15 seconds before it turns itself off I...
No particular problem with your unit. In your case it appears that the fan isn't operational - open the laptop and replace it.
Also check in the BIOS the shutdown temperatures, they might be set way too low.
Sep 08, 2010 | Toshiba Qosmio G15-AV501/R Notebook
Toshiba Qosmio G15-AV501 will not boot
Subscriber/user FMFM85 had posted a solution for another laptop that worked for me. That was Power down, remove battery, remove power, wait five minutes, plug in power and do not install battery, I rebooted to last known good configuration. This method got me further along.from the absolute DEAD state the laptop was in. Now I know that the laptop is really hosed in other ways. I will keep you posted.
Feb 22, 2010 | Toshiba Qosmio G15 Notebook
My laptop wont start its a toshiba g15
have you tried pulling each stick of ram individually?
if there is still no boot then its safe to say that the motherboard or one of the two video cards has failed. its a pretty common on the qosmio g series
Nov 03, 2009 | Toshiba G15-AV501 Qosmio Notebook
I have a Toshiba Qosmio G15R and I need drivers......
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1299306&rpn=PQG10U&modelFilter=&selCategory=3&selFamily=804517&selModel=1299306%7CPQG10U
There u will find the ethernet drivers, the multimedia video controll drivers is only for the MCE.
The unkown device is something on your mobo, you need to findout what that is otherwise you wont be able to findout witch driver you missing.
Anyway, you will find all avalible drivers for your laptop and XP Pro if you follow that link above.
Good luck to you
If you find my answer helpfull, pls dont forget to vote
Dec 27, 2008 | Toshiba G15-AV501 Qosmio Notebook
I went to the Intel site and downloaded the Intel® PRO/100 VE Network Connection driver here. It worked great. Now if I could find the right audio/multimedia drivers I'd be happy. Hope this helps.
Dec 26, 2008 | Toshiba G15-AV501 Qosmio Notebook
My toshiba qosmio G15R will not boot up and I can't get the cd drive to open to use my recovery disk
look for a pin hole in the front of the cd rom push a paperclip in it and it will open the door then try to reboot write back if it still does not reboot, it may be trying to reboot from hdd or floppy enter bios and check boot options
Dec 12, 2008 | Computers & Internet
My daughter put a password for the bios and cant remember it.
Try holding down the "Left Shift Key" when turning on the system
Nov 28, 2008 | Toshiba Qosmio G15-AV501 Notebook
Toshiba Qosmio G15-AV501 red lines in lcd
See the below "copy & paste from another member" I don't know how sucessful these other owners were, but it's worth a try:
PNWSolutions
Rank:master_s.gif Master
Rating: 77%, 15 votes
I had the same problem, what you need to do is call Pamela Saunders at Toshiba Corporate in Irving, CA and she will get it repaired for you at no cost to you regardless of warranty. This is a bad batch of computers.
The Phone Number is: 800-457-7777 or 949-462-6000
Aug 24, 2008 | Toshiba G15-AV501 Qosmio Notebook
Help with Toshiba G15-AV501 Qosmio bluetooth!!
The solution to your second problem is to insert the CD Qosmio Player Recovery CD. The buttons on the top do actually work (most of the time) yet it seems for some reason qccasionally it takes the CD refresh to get them working again. The picture and sound are great once you have got them working. So, don't be discouraged it's a great PC (once you have resolved your problems) I have had mine for 3 years w/o problems except for this one just described. Good luck.
One other thing I did have trouble with the Bluetooth, I resolved it by buying a Targus Bluetooth dongle, (disaabling all built in Bluetooth) then everything "paired" and worked easily, (unlike the built-in)
Jun 13, 2008 | Toshiba G15-AV501 Qosmio Notebook
Driver for IEEE 1394 BUS HOST CONTROLLER
Download Driver Detective and it will reinstall it and do updates for you.
Dec 12, 2007 | Toshiba G15-AV501 Qosmio Notebook
Toshiba G15-AV501 Qosmio Notebook Logo
766 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
