Question about U-Line Icemaker
U Line CLR60 Ice Maker gets stuck in harvest mode & melts ice
Apparently there is a solenoid valve that reverses the flow of refrigerant when the controler board tells it it is time to harvest ice. my unit has always had problems but recently has developed an intolerable issue whereby the unit begins harvest mode after 10 or more cycles and gets stuck in harvest mode. this causes the grid to get hot and stay hot, 100 degrees or more. the compressor continues to cycle, fan runs, etc. but the grid remains hot. i am told that this is due to faulty solenoid valve and am going to order this part and attempt to get it repaired. any ideas beyond this would be great.
  • Turning Wrenchs Jan 14, 2012
    Know this is a way old post but I don't think Uline ice machines have hot gas solonoids. Pretty sure they're just glorified residential units that use a heater and a timer. And the box it self is not more they a small freezer with an ice maker in it.
    Problem Solver:
  • 10 Answers
Have you got the equipment to change this solenoid valve? you will need a vacuum pump to evacuate the system once you have changed the valve, and the equipment to charge the system with refrigerant (gas).
Posted on Feb 04, 2009
How do I know if I have a bad water inlet valve for the ice maker.
U have continuity on both valve windings. Perhaps the ice maker solenoid is stuck in the closed position and not allowing water to pass. Reverse the solenoids (tubing and wiring) and see what happens to aid you in your diagnosis.
Dec 08, 2015 | Kenmore Refrigerators
Ice make hose keeps poping off
The reason your fill tube to the ice maker is freezing up time and time again is simply the valve, or valves (water valves) that dispense water to the door and ice maker. It most likely always is the ice maker side because it is always harvesting ice and it gets used the most. The only way to stop this is to replace the water valves almost always located in the rear of the Refrigerator with the supply line coming off the wall the valves with one or two electric plugs that energize the solenoid type valve when unit calls for water. Tired of getting out the hair dryer and melting the ice that plugs up the fill tube? This is the only solution. Some of the time is because lime, or other deposits in the water will not allow the plunger to rest in the complete closed position. When the valve is energized for the amount of time needed it lifts the plunger allowing water to flow through. Then when it goes back down
to the closed position it has a small gap that causes water to seep through. There you have it! It's fixed! Unplug unit before replacing valves.If you have a double valve system make sure your lines go back to the original spot. Some of them have a 1/4" line with plastic compression fitting for the ice maker and a 3/8" for the water at the door. Some have both 1/4" compression fittings coming out like "Amana" so once again, make sure to get all lines back to the same position.
Dec 08, 2011 | Frigidaire Refrigerators
Water is not flowing into my ice maker in my freezer
Good day,
Lot's of reasons for your problem, but just use the following steps and you should get there. It is important that the freezer be at normal temperature for the ice maker to function. Usually no warmer than 10 degrees.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Sep 11, 2010 | Kenmore Refrigerators
I have a Jenn Air French Door Bottom Freezer. Water dispenser is okay. Ice maker is not making ice.Metal/Wire that operates on/off is missing part of wire but part going into ice maker is still there. Any...
Good day,
The wire must be inserted properly, and when in the down position is in the ice making mode. As the cycle is initiated to harvest it will go up and then when the harvest is complete.
It is a one piece wire, so I don't understand how part of it could be missing.
However, if it's in the down position you can follow the troubleshooting guide below. It would be smart to first take the ice maker into an appliance parts house, and fitted with a new wire. It's a simple proccess.
Jul 17, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Ice make has stopped making ice
Good day, lots of reasons an ice maker will stop making ice. Just take a step by step procedure and it will solve the problem.
The freezer must be at normal temperature. At least 12 degrees or colder.
Jun 23, 2010 | KitchenAid KSCS25FKSS Side by Side...
My ice maker has stopped making ice. We had to shut down the main water valve to the house and after returning the water to the house is when the ice maker stopped working. We have established that water...
Good day,
For all reasons it is best to do a step by step procedure to get the ice maker up and running.
Apr 07, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a whirlpool side by side refrigerator and the ice maker is not making ice. Apparently the water is not getting into they tray that makes the ice. Should i turn it off and wait for it to defrost??
Good day,
That might help, but it is better to follow a step by step process to solve the problem. Your solution, in a way is part of the process that follows.
Feb 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool ed27dqx refridgerator quit making ice immediately after I had my reverse osmosis drinking water system upgraded. I replaced the ice maker unit and the dual water valve. I have always had water...
The pressure from a reverse osmosis system is not sufficient to operate the ice maker water valve. A water valve requires a minimum of 20 pounds of pressure without a refrigerator water filter, and 35 pounds of pounds of pressure with a refrigerator water filter. Manufactures do dot recommend installing an R/O system on the water supply to a refrigerator. The pressure may have been higher from your old system.
Apr 28, 2009 | Refrigerators
Ice maker does not make ice.
JOEHUNT TRY THE WATER VALVE ON THE BACK OF THE REFRIG BEHIND PANEL MAKE THE ICE MAKER GO THROU A HARVEST OR JUST WAIT TO HEAR IF IT GOES THOU A HARVEST THEN YOU CAN SEE IF (1) YOUR ICE MAKER IS ACTUALLY WORKING OR YOU NEED A WATER INLET VALVE ITS 1 OF THE 2 MOST LIKELY THE VALVE
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
Just had this issue - after checking all line connections, I pulled the ice maker feed water line from the back of the unit and found the tube was blocked with ice. Melted the ice with some hot water, and all is good once more. I would check for this before getting into the solinoid.
Aug 27, 2008 | Refrigerators
U-Line Icemaker Logo
726 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
