Question about Krups Small Appliances Espresso Machine
Krups XP9000 won't recognise water tank is full
Our Krups XP9000 keeps telling us to "Fill Water Tank", however the tank is full & seems to be in position correctly. I have tried this both with and without the water filter fitted to the tank.
The machine is out of warranty - I was wondereing if there is a reset function on these machines or if there is another solution I could tried.
I have already tried switching the machine off a number of times & have also tried pushing just about every button on the machine, but it will not move from the "Fill Water Tank" screen. On switching the machine off, it does rinse, so it seems that water is getting through.
Cheers.
Jason
I have just had the same problem with my Krups XP7240 and I discovered (quite by accident!) that it was the magnetic float inside the water tank which was causing it. I think the float must have let some water in and always stayed on the bottom even when the tank was full. As the float was in an enclosed plastic column it was a bit hard to access, but through sheer desperation I snapped a plastic fork in half and wedged the handle section under the float to keep it off the bottom and this works nicely. It is not professional by any means but I was quite pleased with my innovation :)
The only down side to this 'method' is that the opposite is now true and when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid killing the element completely.
I would imagine that the only professional way to get this sorted out is to replace the tank (or float if it is accessible?). Good luck!!
Posted on Mar 08, 2009
  • valyal May 21, 2011
    Thank you very much, I would never thought that the cause could be that little black magentic float.
    I have empty the water tank and then I was shake it throughly. Probably water was entered inside the magnetic float and it can not float any more. After I put water back in the tank, the float works and the problem is solved.
    Thank you
The magnetic float on the back of the tank gets waterlogged over time and stops floating. You can use a very thin piece of metal to attract the float and slide it up into the position where the machine thinks water is in the tank, and then tape the piece of metal to the back of the tank. The magnet will stay up due to attraction to the metal and the machine will now register the tank is always full. You have to keep an eye on the water level and make sure you never let the tank run dry or risk burning out your pumps inside the machine.
Posted on Jul 01, 2011
This was absolutely the answer to my "Fill Water Tank" problem. I managed to dislodge the float where it was stuck at the bottom...I gave it a good whack...and now the machine works like new. Thank you so much for the tip.
Posted on Apr 04, 2009
    New Friend:
Great --- this worked for me ... I jammed it up with a paperclip ... but will (try to) buy a new tank as a safeguard against burning out my heater in the event i run out of water
Posted on Sep 14, 2016
    New Friend:
Hmm, too bad, guys... This elegant sollution is not working for me. :-( My magnetic float floats perfectly, but the machine still does not recognize the water tank is full. :-( Any ideas?
Posted on Sep 13, 2015
What does code 26 indicate?
Check the float in the tank, if it is not floating up from the bottom then jam something plastic underneath it to activate the water level sensor. You can either continue to use it like that ans check water level before you brew or buy a new tank, there is no repair for a float.
Jan 23, 2016 | Krups Ea9000 Barista Espresso Machine
Tip
Krups espresso machine keep asking me fill up the water tank even it is already...
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons.
First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it cannot be fixed then you need a new float.
If you want to fix it temporary until you find a new float you can use a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
on Aug 16, 2010 | Coffee Makers & Espresso Machines
How to remove safely plastic casing on Krups XP9000
Remove book holder at back by pulling it off by hand. Undo the screws visible at the back cover, there's about 4 or 5 or so there. Unclip that centre back panel now screws are out. Remove clear beans cover, remove water tank, lift up the lid to drop grounds direct to brew chamber. Both side lids in open position. Now firmly grip the top cover and try and slide it directly backwards. If it is stuck a firm thump against the front side of the cavity you removed the water tank from while still pulling the top cover backwards will free it up. The sides lift directly upwards to get them off. When replacing the water tank side panel you need the front door open to clear a little spring leg.
Oct 19, 2014 | Krups Coffee Makers & Espresso Machines
How do I rest a krups 8200
Probably the magnet that indicates the water level to the electronics inside is not floating any more. Either replace the tank or wedge something plastic underneath the magnet to trick that the tank is always full. You will then need to check water level visually and not wait to be told.
Sep 20, 2014 | Krups Coffee Makers & Espresso Machines
My water recipient is full, when i try to make my coffee, the machine still asking to fill the tank
Lucky for you the problem probably doesn't lie with the machine but the water tank. Inside the tank there is a flow meter (that little black box). That black box contains a pc board that connects to the machine to tell it how much water is currently available. If that piece does not work properly and the flow meter does not rise (inside, you can't really see it) when water is put into the tank, your machine will think there is not water available to make espresso. Try replacing the tank first then go from there.
Sep 20, 2010 | Krups XP7230 Compact Super Automatic...
Keep asking me fill up the water tank even it is already full
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons. First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it can not be fixed then you need a new float.
If you wand to fix it temporary until you find a new float you can a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
Apr 02, 2010 | Krups Small Appliances Espresso Machine
Says "Fill water tank" and the tank is full
did you open the side valve to ventilate the air in the system in our water tank do you have a little magnet its in the water tank maybe it stuck downshake the water tank to move the magnet up pierre
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
I Have a Krups Espresseria automatic coffee machine & my problem is the water indicator in the water tank does not rise when the water tank is full so the machines keeps telling me to take the water...
Good luck
Nov 17, 2008 | Krups Small Appliances Espresso Machine
"Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Krups Small Appliances Espresso Machine Logo
1,777 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
