No that didn't work, when the cell is formatted for time it won't keep the : signs for time in the cell and still goes back to o:oo if I type in a time exp: 10:35, then move from that cell and it still says 0:00. HELP!!!
You can't post conmments that contain an email address.
right click on the cell your are typing into, and check the format 'Format Cells' - change the format to 'General' - or choose another format. Highlight a row/column or several cells to change the format of them all.
Remove the battery and the SD memory card, check the card for corrupt/virus infected files that have corrupted the software. Now have it scanned on your PC and remove/format the card.
Reset to the phone and check , if the fault comes back then the software must be installed on the phone. have this done at the Nokia care/support center.
The quick way is to right click on the cell, and select format cells. Then click on the numbers tab, under category select Custom, in the Type box, put 0.00.
This will put the format to 0.00 when there is not other number in the cell,otherwise it will jsut keep any current number to 2 decimal palces.
it should be possible that some type of virus occour in your phone memory so firstly plz format your mobile with putting this code. but plz. remove your mmc card and sim card before doing this and keep a phone book number back up in your sim card because during formatting your entire contact details and images and messages were deletd. code is *#7370# and password is (nokia by default) 12345. only type this code in your mobile fone. after that plz. format your mmc card with a help of virus free computer after that put mmc card in tha mobile. thanks
rgrds: Rajiv kumar 9811461147
try to choose repair after you are booting from cd ...like you re-install it ...but choose repair at the second time ...after the system files are loaded ...after this ...just type the ..fixboot command ...or choose a command from the list by pressing f1 ( probably...there are guiding choices anyway...) my solution is to reinstall it ...and format the C partition ..its the safest way..and easier..one too..if you dont want to loose any data from this partition ..install it in the same folder first ..without format it ....move all data to D partition ..then reinstall a clean windows ..by formating the C partition...this will asure you a safe future run...
Possible Problems:
1. Maybe there's a virus.
2. Often restart can drain the battery.
Possible Solution:
Format it by pressing the green key or call key + no. 3 + asterisk(*) at the same time. But 1stly, turn off ur fone, then b4 the NOKIA logo appears, hold these following keys altogether. You will see the "Formatting" word afterwards..
OR...
Format it by typing *#7370.
Let's start with the 1st equation. I assume you want to be able to recalculate by changing the number of pages.
Put 65 in cell a1. 360 in b1 In C1, put the formula =a1/b1 that's your book thickness In D1, put .02 for the cover In E1, put the formula =C1+D1
Now you can change A1, B1,or D1 and the Total thickness gets recalculated automatically. Be careful not to type numbers into C1 or E1, or you lose the formula.
The same for the other equations - a cell for each number ("variable") and another cell for calculations.
Once you've verified the results, then you can get fancy and add titles above each field to make it easy to remember what goes where.
You may need to change the cell format to control the number of decimal places, or thousands commas. Right click on a cell and select format to see the choices you have.
Keep a backup copy of the spreadsheet in case someone (not you, of course) makes a mistake and overwrites the formula cells. You can also look into "protecting" cells to keep them from being changed.
HELP!!!
