Question about Adaptec Computers & Internet
Random wrong passwords
For instance, if i enter the password for my wireless network i get "wrong password" message... i remove the password from the router and connect without any problems, all the other computers at home connect with no problems at all. However i can connect to another network at home with no troubles (with or without password)
  • dejan_0401 Feb 04, 2009
    i can connect to the network with another computer.... when i try to connect to the same network with my laptop, it says : wrong password, and i KNOW it is the right password because i have connected to the network before, and i am administrator...
    but, there is another connection in the house and that one i can connect to with both computers with no problem....
    just for normal wireless operation... well however i have checked and doublechecked the password and no luck... i'll try to borrow another router from a friend... for now... i will just remove the security and then it works fine :)
    thx for trying :)
    President:
  • 1,214 Answers
Any router that your connecting to wireless, without a password, does not have wireless security set up on the router.
Any other wireless router that you are trying to connect to that does not allow you to connect wireless, has wireless security set up and that same security must be set up on the wireless device (like laptop or desktop, whatever is not connected via ethernet cable.).
Reply back what you find and I will be glad to help more.
Posted on Feb 04, 2009
  • Mark Egan Feb 04, 2009
    I would be inclined to say you've got something wrong somewhere in the security setup for the router you cannot connect to.
    You know the wireless card is good because it connects to the other router.
    The hardware is pretty stubborn when it comes to passwords. It won't let you in because it doesn't know who you are. And it's not going to offer up any advice.
    I would connect to the router that doesn't want to connect with an ethernet cable, and double check each letter, one at a time.
    Now, one other thought, are you trying to access the web interface page on that router? Or are you just trying to connect to the router for normal wireless operation?
    OK. Thanks for using FixYa. And if you don't mind, would you update you rating to at least something better than inappropriate. I really feel that I offered you good advice, considering the way your question was stated and without actually being there to see what you are looking at. Plus, I will be happy to keep working to get you a solution.
All network connections are checked but can't connect to Roku receive error message code 011
Please try unplugging the Roku from the electric outlet for 5 minutes, then plug it back and try again.
If no luck, please try resetting the Roku pushing the reset hole on the back or bottom of the Roku for 20 seconds (the Roku must be turned on), and then after the 20 seconds release it and wait for it to restart. It may take like 3 or 5 minutes to restart after the reset.
Then please follow the steps below from your ROKU:
1- Go to the Settings menu, then click "Network"
2- Then you need to select "repeat guided setup"
3- Select the name of your wireless network.
4- Then if prompted, enter the password XXXXX your wireless network. That's it!, it should work now.
If you get an error message here, then probably you are entering the wrong network password. Do you know your wireless network password?
Please let me know if the issue is not solved clicking the "Reply to your expert" gray button, so we can continue troubleshooting.
Please scroll down and click the green button so I can get compensated for my time
Aug 22, 2014 | Roku Streaming Stick HDMI Version
Error code 011 on roku setup
Apr 20, 2013 | Computers & Internet
How do I set up a secure password?
For trendnet
Your Trendnet wireless router lets you broadcast your home network across your entire house, so you can access the Internet in any room. This signal may be powerful enough to extend into neighbors' houses, where they could easily jump on the network if it is unsecured. To protect your network, set up Wireless Encryption Protocol, or WEP, to encrypt data and prevent access unless the user enters the correct password.
Type "http://192.168.0.1" in your Internet browser's address bar and press "Enter." Enter "admin" for the username and leave the password field blank. Click "Log In" to log into your Trendnet wireless router's administrative program. Click "Wireless" from the left pane of the "Basic" tab. Click "WEP" under the "Wireless Security Mode" section at the bottom of the screen. Enter your preferred password for the network. A strong password is made up of a random selection of numbers and letters. Click "Save Settings" at the top of the screen to save your WEP settings.
trendnet wireless router users guide
http://downloads.trendnet.com/tew-611brp/manual/ug_tew-611brp.pdf
Mar 26, 2013 | Trendware TEW-452BRP Wireless Router...
How do you enable security for linksys wireless routers
  1. Type "http://192.168.1.1" into your Internet browser, and press "Enter."
  2. When login page opens up, type the username and password for your wireless router.Depending on your router brand, you may have "admin" and "password" as the respective default username and password. But again, you must refer to your wireless router support manual.
  3. Once logged in, click "Wireless Security" and Select "WEP" as the security encryption type
  4. Set the default transmit key to "1".
  5. Type in a passphrase and click "Generate". This generates random passkeys.
  6. Note down your network's SSID (listed on the security page) and the first WEP key. This is the information that you will need when trying to allow new connection through the wireless network.
Aug 22, 2012 | Linksys Computers & Internet
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 | Cell Phones
NETGEAR Wireless router: I installed it as per instructions on my PC - didn't really know what exactly I was doing....I have Time Warner cable (RR). Now my i phone and NetBook show a wireless network...
You router is sending out the signal under the network of Ellen-p. you need to enter the password to both your cellphone and netbook. Once entered, both devices will remember the connection.
The password is normally issued with a router from an internet provider (Time Warner) and is called a 'WPA2' password is normally a set of random upper and lower case letters and numbers like AAP7CD81. It may be that you set up a password when you set the router up, in which case you use that password.
Another possibility is that the password is on a sticker on the router or on a sticker that came with it.
Jun 22, 2017 | NetGear Wireless router EN Fast EN
I have a belkin g plus mimo 3ASF5F router which is unsecured. I want to enable a security password. I have tried by using the WEP connection on properties security and adding a password but it immediately...
you need to set the password in your computer's network connection as well:
control panel --> network connections --> wireless .
find your SID network and delete it.
then re-scan for network connections and when it finds it will ask for the password.
enter the password and you should be good to go
Oct 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't secure my home network
Hey, you're on the right track however, you'll just need to synchronize the settings on the computer. Follow the steps below.
1. Open the router's admin page (192.168.1.1)
2. Go to Wireless > Wireless Security
3. Security Mode: Select WPA-Personal
4. On the WPA-Shared Key or Passprase box, type your desired password. (Minimum of 8 characters.)
5. Take note of the password, click on Save Settings.
6. On your laptop, open Network and Sharing Center
7. Click on Manage Wireless Network.
8. Please remove all the listed networks
9. Click on Add > Add a Network in Range
10. Select your network and click connect.
11. Type the WPA password that you wrote down and connect.
You should all set.
Dec 02, 2008 | Linksys Computers & Internet
Computers & Internet Logo
99 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Robert Graf
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
