Question about Compaq Presario 700 470024-192 Notebook
Power for charger on pc goes on and off
When i plug the charger plug in it doesn't make power all the time
  • georgewsaxin Feb 04, 2009
    thank you t send it in
  • 679 Answers
Thats common with laptops, the connector is lose on the laptop. You need to send it in to get that fixed, it's not something you want to mess with unless you are qualified to taake apart a laptop. you are looking at about a hundred dollar repair, by a qualified tech, may be more depending where you live, my buddy get''s a hundred in New Mexico, in Boca Raton you will pay $150, but that's the range, they have to take the whole notebook apart, it's a pain in the **** to do.
Posted on Feb 04, 2009
My laptop struck by the lightning. The power LED doesn't turn on, but the wi-fi LED turns on without power on, CPU fan starts as soon as i turn on the charger. But turning on power button has no...
Try to check if battery is removable. Remove all power source (battery and charger). Press power button for 10-20 seconds. Plug in with charger. Power on.
Sep 14, 2013 | Computers & Internet
My dell Inspiron mini won't turn on. I have
disconnectt the adapter+battery and HOLD the power button by 30 seconds. in order to eliminate any EDS, in the power. And try again.
However if the problem persist, test very well the adapter+battery and in the c.board of computer for some cold solder contact, etc God bless you
May 21, 2013 | Computers & Internet
I have a Toshiba PSAF3U-0NR00V, every time i plug the charger to the laptop it goes off, but comes on without the charger, it would charge the laptop,when it's turned off but if i try turning it on...
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 23, 2011 | Toshiba Satellite A205-S5804 Notebook
Hi i have an HP Elite Book 6230p,my laptop stop charging recently, i was charging it and i removed my charger plugged in another charger of lower current rating it worked well for a while, but when i...
Nice books, have many. 8540s./. better.
i can not decode this post.
does it run with no battery and the correct pack
mine has 10 options new the i7 and the fast video card suck huge power and mine needs a 100watt pack, the 65w on mine is HOPELESS. see?
run the correct matching pack,
step 2 a new battery, i keep 2 good ones all the time
on Vacation, id not be wanting to find batteries 3000 south of here, ever. (south of the boarder)
test with no battery
then with correct power pack (the charger is a chip inside the pc and in this 19vdc pack its only a power pack pure DC.
then try a new battery ,
if you read your service manual at
it tells you all packs used and why, and the match.
sure does.
and varies by OPTIONS DAY1. in all case
unless upgraded like mine, is, and sucks max amps mine does.
Jul 03, 2017 | HP EliteBook 6930p Notebook PC
Hi, My l305-s5875 Satellite laptop stops working when the power adapter is plugged in and the battery doesn't last more than an hour.
I've seen this happen on several different cases. There could be one of two things that can be going on.
1. Your Charger is bad (but not completely bad). I mean that it took an inverted charge and every time you plug it in, instead it turns off your computer, or drains whatever power you have in it. It can rightfully explain the lowered usage of your battery.
- Sometimes taking a magnetized object (like a screwdriver) can be touched to the tip of the charger and it can reverse the polarity. WARNING!!!! UNPLUG THE CHARGER BEFORE DOING THIS!!! YOU MAY GET YOUR BRAINS FRIED IF YOU DON'T!!!
I would say that maybe 60/40 chance it would work. Otherwise try another charger. Universal chargers can be bought at or Best Buy relatively cheap. As low as $35-45.
2. On the motherboard, there is the plug-in area where the charger goes. It might be experiencing a short. This can usually happen due to faulty wiring, or a fall, bump, hit, or crack to the computer.
On a side note. If your computer is over 1.5 years of age, the battery is going to start lasting less and less. Most Lithium-Ion batteries have a primary lifespan of 2-2.5 years. Some go out before, some go out after. It's all a bell-curve.
Please Rate
Jul 08, 2011 | Toshiba Satellite L305-S5875 Notebook
My Acer Aspire One D255 will not turn on. Light shows blue then immediately goes off. Won't boot on or anything.
Make sure that you have a charge. Try plugging it in and turning it on. If it still doesn't work then you might have a low battery, bad charger, or there could be a problem with the power supply. A bad charger and or a bad power supply would require replacements. You can probably find the charger at best buy or The power supply could probably be found at You might try taking it to a local electronics store and see if they have a different charger they can test it with, that way you would know for sure it isn't the charger.
May 03, 2011 | Acer Aspire One Netbook
Have not used my Garmin since January 2011. Sitting on shelf. Plugged in to my car charger and would not turn on. Would this mean it needs charged?
After three months, I'm sure the internal battery needs to be charged. But even so, it should work when plugged into the car charger. The first thing you should do is check that the charger cord is connected properly at both ends. Mine has a green LED on the plug. If yours does, make sure that light goes on. Try jiggling the connectors at each end of the power cord. If it still doesn't work, the next thing to try is replacing the power cord. (Maybe you can borrow a power cord from a friend). If the power cord isn't the problem, I'm afraid the problem is in the Garmin itself. Good luck.
Apr 18, 2011 | Garmin nuvi 1490T GPS Receiver
Plug battery into charger light goes out
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Apr 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
