Question about KitchenAid Dryers
Noisy my dryer is 13 month old! 1 month to old for warenty!! its very nosy when is running!! and not hot enough. I called Sears and they tell me to bye and extende waranty , but i dont know???
  • 640 Answers
Call kitchen aid directly and hollar,,,they will send a tech...onthejob
Posted on Feb 04, 2009
Changed door switch on my kenmore h2 plus cause of error code and it still wont work
Whirlpool & Kenmore Dryer Repair #01 - Won't Start or Run ...
? 8:50
https://www.youtube.com/watch?v=2WF71WdGn_g
Oct 19, 2011 - Uploaded by canyonman1963
This one deals with testing and replacing the door switch. ...sears wont work wont spin wont wash wont heat wont start fix repair bad noise noisy ... how to change a 4 to a 3 prong cord, to figuring out my door switch problem.
Dryer Door Switch - How To Replace - YouTube
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
So if my washer wont start just call Sears. .... Bad sears mykenmore is only 2 years old, fill take 30 mins,,,wash 50 mins rinse never spin never,, ...
Nov 28, 2015 | Kenmore Washing Machines
Motor power suging up an down
Its in the carb linkage which controls the choke and the throttle position..its just a pain to use it.. won;t hurt anything.
hard to imagine people still buy larger items from sears these days..sorry...
Sep 11, 2017 | Craftsman YT 4000 42" Briggs Stratton 24...
13 month frig quit running
Here is what I would do:
I would check to see if the compressor and condenser fan motor is running.cc8d7bd.jpg If the compressor was hot to the touch that would give me a clue.
That would tell me the relay is stuck in start mode causing the compressor to get hot and quit.c6b5f66.jpg I would remove the relay and put my HS410 start pack to see if the compressor comes on and I would check if it was over amping. The amp draw should be around 1 amp. If it is running 7 or 8 amps then the compressor is shot will over heat and die.b261986.jpg The fan motor by the compressor should run when the compressor does. So if the compressor is running but not the fan then you need to look at buying a fan motor. If the fan is running but the compressor is not then you need to buy a relay. If all of that is ok I would next listen for the fan motor blowing in the freezer, no fan no cool. Lots of times fans will make a racket if ice begins to build in the evaporator.c4cad85.jpg They will get louder and louder. Then the ice will build to the point the fan won't blow.
I would need to check for a bad defrost heater or terminator if that is the case. Do this test: unplug the ice box and let it sit for 3 or 4 days till it completely thaws out. Then plug it back in. If it begins to work ok then you KNOW you have a defrost problem. Replacing the defrost thermostat and heater is not very difficult, you still need to let it thaw out to do it. Even if you called me out there and I said it was a defrost problem I would still have to leave and come back 3 days later. If you suspect it is the defrost then go ahead and clean out the ice box and let er sit for 3 days. Then until you can fix it just unplug it once a week like grandma did back in the 40s before auto defrost. That's all the smart pills I have. Post a model and I could be a bit more specific because you could have adc0c1e867.jpg or a timer a control board instead of a mercury based control and in that case their is much more to check. For instance if you had an old schoo timer,8c078f4.jpg it might be stuck in defrost. It might just take moving that timer screw forward to get it unstuck. Don't know until I see a model number. More here
Jun 11, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Microwave stopped working and was hot inside.
At just 13 months old I would be inclined to get in touch with Maytag. If you make enough fuss they will repair it under warranty. but just check that the air intake and exhaust are clear of debris first.
Hope this helps
Jan 07, 2010 | Microwave Ovens
Glow igniter shuts down when dryer calls for gas
The very noisy part is a little bit odd...
Usually the igniter glows, the flame sensor detects the glow and sends power to the valve coils, which open the gas valve. There are some differences in that setup depending on the brand, but that is basically it.
It could be that the igniter isn't glowing hot enough (doubtful) or that the flame sensor (the rectangle thing on the side of the burner tube) isn't working (also unlikely, but still possible) or that the gas coils aren't working. Gas coils are the most common problem to go wrong on gas dryers, but when they go, they usually work at first, and then start to fail.
Do you have a volt/ohm meter?
Nov 14, 2009 | Whirlpool LGR4634J Gas Dryer
Brown marks on clothes from kenmore elite dryer
i used to be sears repairman ask him if there is a recall on your pacfic model .. betcha there is on the dryer drum tell him u want the whole drum replaced on dryer u know exsisting problem having on this pacfic dryer remember satisfaction gaurented or money back...
Jul 12, 2009 | Kenmore Elite HE4 Electric Dryer
Hello my dryer is only 3 years old. Last night it stopped drying. The drum will turn and the light comes on. It is an electric dryer. What might be the problem. Thanks.
Have you tried a different cycle? The thermostat that controls heat has failed. There are more than one for the different heat settings. Try a different setting, then go from there.
Jul 01, 2009 | Dryers
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
13 months old Kenmore compressor very hot.
lacdoi,
huuum At your service!
You said,
The warranty just ran out, Sears came out told me needs a control board ($210 for just labor to replace) not sure about part price. I though a new freezer is about twice his labor and parts, so I sent him away minus $65.
I did some troubleshooting today, pull the plug for 2 days. Plug it in, temp alarm goes on all the time. Turn alarm off, left the freezer running for 4hrs.
Not cold at all, some cool air. Fan is on, compressor is on (can hear humming noise and is vibrating). Compressor is very hot to the touch, could burn finger.
Should I call Sears again, wonder how much to fix all the problem? Or just give up, look for another brand new one (not Kenmore).
MY ADVICE:
Sounds like a big repair bill and multiple problems
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliance are so much more efficient today that they can save you a lot of money in energy!!!!
Replace it.
You will be fine
Bless You huuum
Please give me the best rating for my fine advice before you sign off.
Thank you
Sep 17, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
May 08, 2008 | Dryers
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
