Question about iLO 3200 32 in. LCD Television
No digital channel
My digital channel as stopped working when i put av channel on its okay when i press button for digital channel no picture
I have fixed the problem
Posted on Feb 04, 2009
What chanel do i put tv on to watch dvd movies
You are trying to work out how to watch a DVD movie on your TV
The DVD should be connected to your TV with Audio Video cables.
And it will most likely be connected to AV1 on your TV
The easiest way to find out would be to
  • Put a DVD in the Player and press play
  • Now the TV is probably in channel mode, so find the button on the TV remote that says TV/AV
  • now press this button TV/AV and it will scroll from TV channel to AV1, AV2 etc until you see the DVD picture.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | GPX D1816 DVD Player
F2-1000T Digital Set-top Box.
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
Aug 05, 2008 | Televison & Video
Playstation 2. All the cables etc, are connected and tight, to their respective locations. I just do not know what channel on the TV, that permits game use. I am a pensioner, and unable to find the...
It isn't a channel, you will need to switch the video mode from cable TV to auxiliary inputs (i.e. VCR, DVD player, games, etc). The process for doing this varies from TV to TV but generally the remote will have a button that says 'Input' or 'Video' and that will switch it.
May 30, 2011 | Sony PlayStation 2 (PS2) Console
People faces and a lot of other items on the screen are not natural looking, kind of like a manaquin. Stripes are distorted. It is brand new and I was wondering if the problem is the tv or something else....
On this television you would need to remove the Comcast digital cable box. This tv does not need it. Then you will press the menu button and choose either the channel or the setup category. You will then need to locate the auto ch memory or ch setup subcategory. Then you will select it by pressing enter after scroling down to it. Next you will scroll down to automatic search or ch search and press enter. Select search start for just digital channels and press enter. It may direct you to select yes and then enter. After the television is done searching the 135 channels it will come back to channel 2.1 or the lowest channel you receive. You can then go through your channels with the ch button on your Sharp remote control. The picture can further be adjusted with the av mode button on your remote if you press it repeatedly if you remote control has one.
Apr 17, 2010 | Sharp 19 in. LCD HDTV
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
PENTAX IST DS PROBLEM WITH INTERNAL FLASH
First make sure the camera is not set to No Flash on the shooting mode dial.Also, in P, Tv, Av or M modes the flash reverts to manual and must be raised manually by pressing the button next to the viewfinder.
Jan 11, 2008 | Pentax *ist DS Digital Camera
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
iLO 3200 32 in. LCD Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
