Question about Microsoft Xbox 360 Console
Sounds like a bad fan
I turn it on and it works and runs just fine. it has froze once in the past few weeks and in those few weeks it has also become loud. it sounds like a fan is going bad because it makes a loud noise that sounds like a fan. it has to be a fan or something of the sort because when i turn the console off after playing it for a while it will stop. but it doesnt stop immediately. it gradually slows down and finally stops so that's why i think it's a fan or something like it.
  • 38 Answers
Over time, everything gets old. I suggest buying a "Inter-cooler" it helps keep everything cool, and takes a little less pressure off the fan.
Posted on Feb 04, 2009
Burner shut off then there is a clicking sound, burner ignites again
this is normal the clicking sound you hear is the system starting another cycle for your furnace to ignite the burners, then turn on tbe fan blower.
Sep 27, 2017 | Heating & Cooling
Carrier High Efficiency Weather Maker 38TZA024320 8 summers No Cold air controls are working the fan turns on when the compressor tries to start you here a short buzz repeats every couple seconds over the...
Hello
It would be worth a try to put a new start capacitor on.Also check the compressor contactor for burt or pitted contacts and replace if needed.
If this is a three phase unit be sure you dont a one blown fuse in the disconnect box.
Aug 03, 2011 | Carrier Heating & Cooling
I have a proxima 6850 and at least once a week it shuts down like the lamp has gone out, I turn it off for a minute from the power switch on the side of the projector and when I turn it back on it works...
Sounds like a heat issue, direct a small table fan into the unit next time and see if it stays on longer. If so then you may want to blow out the case with compressed air to get dust accumulation off heat sink or internal radiator.
Oct 19, 2010 | ASK Proxima PROXIMA DP6850 projector lamp...
For the past few years the small fuse in the washing machine blew about once a year. A few months ago it seemed to blow every week. Then it was fine again. Now I replace the fuse and as soon as I turn on...
One says the lid switchs are not working in tandem with each other. Another says the circuit board is bad. I say it is because it is a Maytag and built with an obsolete ethical plan for generating profit.
Dec 29, 2009 | Maytag LSE7806A Top Load Stacked...
Heat pump not cooling
You may have a bad running capacitor on the outdoor unit. It is a round or oval can with three sets of prongs on it. Over time they can either become weak or swell due to an overload.
Aug 10, 2009 | Heating & Cooling
The utopia is powering up, but the heat plate is not heating up
You need to explain the problem better....  You are saying that the machine is not boiling the water and the problem has gotten worse ?  It sounds like you may have a loose or corroded wire(s) running to the heating element which would explain the intermittent nature of the loss of heat... If you are not handy with tools and electricity, take it in to a coffee machine or appliance repair place and tell them the problem.
Mar 31, 2009 | Starbucks Barista Utopia
Kenmore (frigidaire) model #253.55679400 evaporator fan does not come on
yes, the fan is controlled by the pcb controller, but it is also dependent on the temperature sensor since it is waiting for the sensor to give the signal that the freezer coils has froze up before turning the fan on.
it could be a bad freezer temp sensor.
i hope i was able to solve your problem,
pls rate me
tnx 4 using fixya
drcool
Jul 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Microsoft Xbox 360 Console Logo
183 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
