Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My craftsman lt 1000 is getting oil in crankcase
The breather tube from the crankcase to the carb is blowing gas and oil and a lot of it.
  • amdsgd Apr 05, 2009
    This was an excellent description on the repair. I have a craftsman 17 horse 42in cut that floods the crankcase as well. Do you think the fix coupd be the same on my mower? I bought this as is from a friend that had the carb rebuilt, but nothing replaced, the guy just took it apart and cleaned it an reassembled it. I am thinking that the solenoid is faulty on the bottom of the bowl. Also, is the fuel shut off a good idea to prevent any syphening of fuel when it is off? Just a thought. thanks.. Ryan in Wisconsin
  • 246 Answers
SOURCE: i need a owners manuel for Craftsman LT 1000 Model# 917.272650
Hello bostont1228:
>>To View a Breakdown of this Unit Go to this Site Addy, and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
Posted on May 13, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Posted on Aug 25, 2009
  • 472 Answers
SOURCE: I have a Craftsman 16hp B&S, 42 tractor. engine surges, blows oil
Posted on Oct 08, 2009
  • 95 Answers
SOURCE: i have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Posted on Mar 14, 2010
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
I have a1996 model Gravely 16hp twin cylinder that has given no problems since it was new. I started to crank it today and it was hydrologic locked. I removed the plugs and left it clear itself out. Put...
1. If it has a metal tank, then it may have rust in the tank which is getting into the carb(s). Look in the tank and see if there is any rust at all. If it has rust then a tank liner kit should be installed like "Kreem". "Kreem" or other brand liner kits are sold at most motorcycle shops.
2. The carb could have trash or rust in it. Remove the carb inlet line and blow litely into the inlet hose.
3. It most likely hydrolocked because the carb bowl overflowed when the trash or rust made the needle and seat stick open. The rubber breather tube shot out most likely because the vapors in the crankcase ignited or there is to much oil and gas in the crankcase now. Once the carb overflowing is stopped, the oil should be changed.
May 03, 2014 | Motorcycles
Oil leaking into carb
All Harleys will get a little oil in the breather.
However, when mileage causes the rings to wear, combustion pressure can leak past the rings, causing higher pressure.
You didn't state your mileage, but at 11 years old, your engine might be ready for a top end rebuild.
Mar 22, 2014 | 2003 Harley Davidson FLHTC Electra Glide...
Breather tube throwing oil into carb
Oil coming via the engine breather can mean a worn engine, it could be as simple as an over filled sump, or the breather valve itself is not working, the breather valve allows the crankcase pressure out of the engine.
Apr 20, 2012 | Cub Cadet Garden
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My troy-bilt blower/vac is blowing oil out of the carb. what are some things that may cause this? Oil level? How do I know I have proper amount of oil? If I leave the foam filter and the carb cover on, the...
Your oil breather (on the side of the engine opposite the carb) may be malfunctioning/defective allowing the carb to **** oil from it. There is a breather tube that crosses over the top of the cylinder connecting the crankcase( oil) breather to the air filter housing. Check the oil level and the condition of the air filter and esp. the oil breather. It serves the same function as a PCV on a car engine.
Aug 09, 2010 | Troy Garden
Kolher 17hp motor blowing oil/gas mix out of breather tube
I had the same problem! I found that the needle valve in the carb was not shutting off the fuel flow when not running. Either replace needle valve or put a shut off valve in the fule line. Should take care of the problem
Apr 03, 2009 | Craftsman Garden
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Mar 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Oil blows out of tube
You either have a head gasket going bad or your piston rings are shot which causes air to go down into the crankcase building up pressure which exits through the breather tube.
Jan 31, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Blowing oil on an 8HP craftsman snowblower
That is a breather tube, I can't picture the motor off the top of my head but that tube is either connected to the valve cover or if the tube seems to go up over the motor then that tube goes down into the motor. If it's the one thats connected to the valve cover then it's possible there is to much oil in the valve box. If it's the one that seems to go up over the top and in then if your just alittle to much over full you'll get oil out of that tube cause that tube sits alittle above the oil level.If your oil level is right on the line then I would run it for a bit then check the oil level. If the level is still good then you should be ok but keep an eye on it if it continues to blow oil out I would take it in to get looked at futher.
Jan 04, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
513 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
